vtec pressure code??????????????? help
I got a 98 b18c5 in my eg. everything is fine except that when i get into vtec for a while (like in third) it throws code 22. I ve checked the screen on the vtec gasket and its good. vtec works so the wiring should be ok. I live in a small town and no one can help. any body have an idea.
p.s. im new so go easy
do you have the vtec pressure switch hooked up? I didn't notice if you mentioned is the B18C a JDM motor? If so some do not come with these sensors and you have to get one and install it.
it is a jdm motor and i looked and its not there so that must be the problem. so now what switch could i use, i have one off of my jdm d15b (obd1) would that work. my itr is obd2 and so is the engine harness but im running a obd1 p28. will an obd1 switch work. also do i have to drill and tap a hole or should i buy a new silonoid (cant spell sorry). What do think? and by the way thanks
Think I found ur problem. Obd2 engines don't use the Vtec pressure switch, only obd1 engine's do. So that's why ur getting the cel for it, cause ur ecu is looking for it when it's not even suppose to be there on ur obd2 engine. So ur fine, if the cel gets annoying just get an obd2 ecu.
I think u're going to have to get an obd2 ecu. Are u saying when the codes comes on it disables ur vtec or when it turns off?
you can use any vtec pressure switch they are all the same. It will screw directly into the vtec solenoid you already have. so just use the one from the d15b and call it a day.
jayeghatch
14
Sep 25, 2012 02:19 AM
Absubtle
Jul 3, 2005 09:48 AM
