vtec not hitting
you need to have oil press @ 55psi (or close to it)
you need to be above 15 mph
and.... damn I cant remember what the 3rd requirement is, but if you have all those, check you wiring for the VTEC selnoid. I would also fix your codes and see if your still getting a CEL.
Blaze
Blaze
Code 6 is the ECT (engine coolant temp) sensor. check that and make sure it's working properly.
It is located on the thermostat housing
Code 7 is the TPS. This causes you to not go into VTEC which throws you into limp mode due to the TPS having a mis-reading, is a defective plug, or bad sensor.
zx2gotboost
Apr 22, 2011 01:42 PM
folta2169
May 26, 2005 08:25 AM
psycho_civic
Oct 23, 2003 08:33 AM
