Vtec Head on non vtec block without hooking up the vtec
Old Apr 9, 2002 | 06:01 AM
big bentley's Avatar
Default Vtec Head on non vtec block without hooking up the vtec
I dont care about the ls/vtec or the b20/vtec.
I want to know if the vtec heads flow better than the non vtec heads (are the vavles diff, etc. ) and if anyone has mated a vtec head to a non vtec block and seen any gains without hooking up the vtec. I guess it would be the same prinicpal as the vtec just not working on a motor..
Old Apr 9, 2002 | 08:02 AM
DOHCtorTHRUST's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (big bentley)
supposily, it should flow better but whats the use of going through all that trouble with hooking up the v-tec unless your going turbo....i know this guy who ran a ls-vtec setup(full race car)with turbo making 550 to the wheels with out the vtec on....so i think it depends on your set up....
Old Apr 9, 2002 | 08:36 AM
rainforest's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (DOHCtorTHRUST)
dude if you put a vtec head on and dont run vtec thats kinda retarted. They flow lots better than ls heads so yeah it would woork.
Old Apr 9, 2002 | 11:34 AM
Default Re: Vtec Head on non vtec block without hooking up the vtec (rainforest)
I really dont like the idea of vtec, and would rather have power down low, when I originally posted I didnt even think about hooking up the oil lines etc.
Old Apr 9, 2002 | 12:42 PM
ExospeedAMcrx's Avatar
Getting VTEC is not the main point when hooking up the oil lines. You need those lines to get oil into the head. No matter what, you still have to run the lines and tap the head.
If you don’t want VTEC, just don’t wire up the vtec solenoid.
Wil
Old Apr 9, 2002 | 02:59 PM
Kamin's Avatar
um hooking up vtec dosent hurt the low end dude. if your gonna go through all that trouble run 1 damn wire and turn vtec on.
Old Apr 9, 2002 | 03:38 PM
infamousALLMTR's Avatar
why dont you drive a domestice then
Old Apr 9, 2002 | 04:27 PM
tinkerbell's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (infamousRRH)
bently, have you ever driven a VTEC car?
or is the VTEC concept just an idea you dont like?
if you would rather have power low down, well, four cylinders ain't for you...
im not wanting to flame or anything, but your question is really weird?!?!
t..
PS the answer is: Honda has tried a VTEC head on a non-VTEC block (the B18A) and decided it was better with VTEC (therefore the B18C).
does this help you?
[Modified by tinkerbell, 11:31 AM 4/10/2002]
[Modified by tinkerbell, 11:32 AM 4/10/2002]
Old Apr 10, 2002 | 07:10 AM
Finest's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (tinkerbell)
Uh, I think you're missing the whole POINT of VTEC. The key point in the VTEC system is the CAMS! Sure, you can bolt on a VTEC head and not hook it up. But what point would that do?...you won't be able to take advantage of the better flowing head without the big lobes. Well, unless you're dropping in some Toda VTEC-killer cams...which eliminates the VTEC system and runs solely on a huge cam. If you don't hook up the VTEC, then you'll only run on the smaller cams. Kinda negates the purpose of a high flowing head, don't you agree?
But then again, you can port the heck out of an LS head, throw in some wild cams, with built valvetrain...and have the same, if not better performance of a regular VTEC head on an LS block.
Old Apr 10, 2002 | 09:28 AM
X2BOARD's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (Prelude_RCR)
Why would you take the torqueless wonder of the primary cam on a vtec head and run it all day ? If you are going thru the trouble of an LS/Vtec, just hook up the Vtec, otherwise... spend the money on a mild PnP job on the LS head.. it will flow better than a B16 and you will keep the stock head config.
The only downside is you will lost a bit of lowend, but the mid-top end gain will more than make up for it.
BTW, I believe the Vtec head is a little heavier than the LS head... plus PnP will lighten it ..
Old Apr 10, 2002 | 11:24 AM
umm, bottom line, vtec sux.
i would like to build a motor that doesnt use that horrible 4 letter word.
Old Apr 10, 2002 | 11:28 AM
I have driven quite a few vtec cars and have not been impressed.
i basically wanted to know if the vtec head flows better or not than a non vtec head
Old Apr 10, 2002 | 11:36 AM
topspeed86's Avatar
Why not buy a car that dosent offer Vtec at all
Old Apr 10, 2002 | 11:37 AM
X2BOARD's Avatar
yes, much, much better...
Old Apr 10, 2002 | 11:57 AM
You must have driven a B16 powered car. B16’s have no torque at all and don’t really feel that fast.
It would be different if it was a straight GSR motor/ITR.
Ive seen dyno numbers of 135HP to the wheels with 104lbs torque on B16’s
While my SOHC is pushing 138WHP with 117lbs of torque.
either those, or the car you drove just sucked.
Wil
Old Apr 10, 2002 | 01:02 PM
Kamin's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (exospeedAMcrx)
vtec sucks?
WHY are you driving a honda?
if your "not impressed" with vtec then a motor without it is going to suck more. your an idiot.
and another thing, if you put a vtec head on a non vtec block and just run on cams that still have the vtec lobe somthing is going to break. the nonvtec lobe on the cams arent made to go to 8000.
[Modified by KAMiN, 2:03 PM 4/10/2002]
Old Apr 10, 2002 | 03:12 PM
tinkerbell's Avatar
Default Re: Vtec Head on non vtec block without hooking up the vtec (KAMiN)
yep.
i have a VTEC switch on my B16A that opens the VSS wire to the ECU...
this switches off VTEC, eg when its raining hard or im freeway driving at 70mph (around 4500rpm in 5th)
the engine still revs to 8000 but it is SOOOO breathless, it feels like she is choking
if you want better flow of the head, without VTEC, get hell lumpy cams, like those circut racing (non)VTECs have,
the cams are designed for over 5000rpm operation where you can take advantage of the free revability of teh engine combined with the good airflows in the head...
yeah, quite a specialised engine = race only, but it does have merits...
what are your intentions big bently?
maybe some enlightenment?
t..
Old Apr 10, 2002 | 06:02 PM
Finest's Avatar
I think Big Bentley, with 10 posts total, doesn't even own a Honda.
But anyways, get your LS head ported if you're so "anti-VTEC". That'll solve any difference between the two heads.
Old Apr 11, 2002 | 03:55 AM
I have driven 3 different b16 powered cars, crx & 2 6th gen coupes.
Your right I dont even own a honda, but I want to build a nice daily driver for my commute. I am a die hard vw guy, but I dont hate on other manufacturers. I realize there is great potential for hondas, there are just to many bad examples everywhere.
I am also not impressed with the lack luster low end of vtec cars. I want a torque monster.
Old Apr 11, 2002 | 07:21 AM
That explains it. Go drive a car with an ITR or GSR motor, the feel is totally different from a B16 motor. the B16 motor is the worth DOHC VTEC in my opinion. NO torque at all. The only thing its good for is the head. Unless you go turbo on it or stroke it to a 1.8L or sumthing. That block is pretty much worthless. That is why B16 blocks go for like $50. No one wants them.
Good luck in your quest for right motor for you. PEAce!
Wil
BoltSOCpower
Oct 24, 2010 03:06 PM
jivi
Honda Civic (2001 - 2005)
Apr 19, 2007 06:28 PM
xvracing
May 1, 2004 01:49 PM
