vtec
Old Nov 8, 2004 | 01:31 PM
b16racer23's Avatar
Default vtec
i just swap a jdm itr motor in my 94 hatch, im having problems with vtec, it kicks in 2 or 3 times but after that the check engine light comes on and vtec stops working ,even when it works it loses power after 6,500rpm i conected all the vtec lines to the ecu and im running a p28 chipped ecu with stock itr injectors and an ls fuel pump. i also have b16a2 cams in there.help!
Old Nov 8, 2004 | 04:27 PM
4gCRX's Avatar
what code is it throwing?
Old Nov 9, 2004 | 09:35 AM
b16racer23's Avatar
Default Re: (4gCRX)
17 and 21
Old Nov 9, 2004 | 09:50 PM
fkncivic's Avatar
Default Re: (b16racer23)
why would u put b16 a2 cams in a jdm itr?
Old Nov 10, 2004 | 02:37 AM
poison's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16racer23 &raquo;</TD></TR><TR><TD CLASS="quote">17 and 21</TD></TR></TABLE>
These are the reasons your vtec is not working.
17 is the speed sensor. Your ECU has to detect your speed before engaging vtec.
and 21 is the VTEC solenoid. You probably have a bad connection or faulty solenoid. I would check the wiring to the A4 pinout using a digital multimeter to verify the connections.
For VTEC to run properly, you must clear those codes.
Old Nov 10, 2004 | 07:24 AM
b16racer23's Avatar
Default Re: (fkncivic)
my cams got stolen while my moter was out, do u think the cams would efect the way vtec is working
Old Nov 10, 2004 | 09:15 PM
boost'dsiR's Avatar
naw it s just the b16 cams a little too small for the itr. itr have higher lift and duration u basically losing power by putting in the b16 cams
nitrousfedef9
11
Oct 5, 2005 09:13 AM
EKhothatch
Sep 2, 2005 09:08 AM
b16mike
May 13, 2005 09:51 PM
wfo
Feb 25, 2005 02:21 PM
c8r9x
Aug 17, 2003 12:50 AM
