Type R in 98 hatch question
I have a 98 civic hatch and im buying a 97 JDM R swap for it. Just wondering what parts i will need for the swap. Will the type r axles work or will i have to get others? I also hear that I will need an SI rear mount for it. Let me know what all i will need. Thanks
If your getting a OBD I motor, which i assume your not, you'll need a OBD II to I adapter harness.
http://tech.hybridgarage.com/tech/6g...wrence-6g.html
http://www.jspectuning.com/6gen/
If I were you I would get a 98 b18c. Keep with the year of the car.
Also, depending on what year of engine you get, you will probably be getting the 36mm axles. They do NOT fit our cars. You'll need to get US spec 94-01 Integra axles.
But I'd wait untill you get everything to make sure they don't send you the right ones. (32mm are right).
