Trying to ref my k-swap
Old Jun 7, 2008 | 05:03 PM
LHDEG6's Avatar
Default Trying to ref my k-swap
I have a 93 hatch w/ a k20 type-s. I'm using a stock engine harness w/ a hybrid racing sub-harness, i've wired up the proper e-vap things and wired up an immobilizer so i can use my type-s ecu. THE PROBLEM... my ecu doesn't store memory 4 its self tests. In trying to figure it out, ive pulled my map sensor witch gave me a check light, then i shut off the car and plug the sensor back in but when i restart the car the check light is gone. The check light should stay on until its cleared with a scan tool. If anyone has/had this problem on there set-up what did u do or r trying i want 2 b.a.r. this thing so any help would b great THANKS!
Old Jun 9, 2008 | 02:13 PM
ekb16's Avatar
i believe ur going to need to convert ur fuel system back to the way K series are which is returnless fuel system to be able to pass bar
Old Jun 9, 2008 | 05:38 PM
superfast666's Avatar
Default Re: (ekb16)
ekb16 is right you wont pass unless you use the return less fuel system
Old Jun 10, 2008 | 09:11 PM
LHDEG6's Avatar
Default Re: (superfast666)
I've already made the fuel system returnless, and its running the e-vap test(s) fine on the scan tool. My problem is that my ecu doesn't store the check lights. On a stock rsx the under hood fuse box (fuse 9) is the back-up, but it goes to the audio unit, DLC, gauge assembly Immobilizer receiver, mutiplex, and security unit but from there none of those goes to the ecu. Is it something in the gauge system or the muliplex that i need to store this check light info, What wire or part am i missing from a stock rsx that lets there self tests/ check lights stay memorized
Old Jun 10, 2008 | 10:35 PM
BolivianFuego's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">i believe ur going to need to convert ur fuel system back to the way K series are which is returnless fuel system to be able to pass bar</TD></TR></TABLE>
Yes, i remember some guy on k20a.org made his car pass and even had the stock K20 Gas tank in his car!
Old Jun 11, 2008 | 10:50 AM
bmoua's Avatar
Default Re: (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">
Old Jun 11, 2008 | 02:02 PM
ekb16's Avatar
ya i think it was a white eg hatch..the back trunk had a huge hole just for the rsx gas tank
Old Jun 11, 2008 | 02:22 PM
Default Re: (ekb16)
ya i think it was a white eg hatch..the back trunk had a huge hole just for the rsx gas tank</TD></TR></TABLE>
Ok, just did some quick searching on there, i am a moderator Matador is my name.
Here is what i came up with, the pics are dead though and this is what he said he did to get it to pass.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20 fit;173498 &raquo;</TD></TR><TR><TD CLASS="quote">
Whats needed...
-EG Your willing to cut up (for gas tank install)
-Complete RSX Gas Tank
-RSX Harness
-K20A2 ECU
-TSX Header
-Cat
-All RSX Smog Equipment
As far as cost goes, Most of the work is fabracation. The best/cheapest way to do it would be to buy a wrecked complete RSX and swap everything over.
The car also has...
-Complete RSX Dash (no air vents)
-RSX Steering Column
-RSX Ignition w/Working Immobilizer
-RSX Signal/Wiper Controls
-DC5 Type R E-brake
-DC5 Type R Center Console
So you would need to get a stock TSX header and cat to fit in a EG chassis.
http://www.k20a.org/forum/show...k20a2
thats the original thread he started.
Here's a newer one someone else made recently. You could both bring them back from the dead if you wish.
Old Jun 13, 2008 | 06:31 PM
UKDMEP3's Avatar
hey man i have 05 ep3 with the a3 i have pulled my map off before shut the car off plugged it back up and the light was gone too so i dont think its the ecu. havnt tried on any other k motors or k ecus though
Old Jun 19, 2008 | 08:56 PM
LHDEG6's Avatar
Default Re: (UKDMEP3)
Thanks for all the replys and the possible help, i talked with someone that suggested i try rewiring my main relay or run 2 relays because the k gets its memory power through the relay. I still need to find out what pin(s) on what connector (A, B, E) i have to use. I already have most of the "whats needed" list except im doing this with my stock gas tank, the evap stuff came out of a newer model honda
gtownjoe
Jan 13, 2012 02:32 PM
vietboycuhz
Oct 21, 2005 09:27 AM
lbirllain
Mar 2, 2005 03:47 PM
RaVAGE00
Apr 13, 2002 02:34 PM
