transmission cases
Old Dec 18, 2005 | 06:46 PM
ED9man's Avatar
Default transmission cases
What other B-series cable transmissions cases (not the clutch housing, the other part), if any are compatible with a 92 GS-R transmission. I tweaked an orifice for the shift rod inside the transmission. I had a transmission shop make shims to correct it, but it doesn't work the best. It is really hard to find one of these transmissions and the other cable ones are really easy to find and cheap so it would be nice if I could get away with a case out of a non-VTEC integra. Let me know if it's possible. Thanks.
Old Dec 18, 2005 | 06:51 PM
ED9man's Avatar
Default Re: transmission cases (ED9man)
I just looked up the part numbers for a 92 GS-R and a 92 GS and they match meaning they are the same part and should work right?
Old Dec 18, 2005 | 08:43 PM
Honda Bull's Avatar
If it's the same part number then yes.
The 92 GSR tranny should just be a B16 tranny... which has typically shared the same parts as the LS (B18A/B) trannies. But again... if the part numbers are the same then you're golden. Good luck... trannies are a pain.
civiceagle2
May 4, 2013 02:17 AM
christion
Feb 4, 2008 03:17 PM
EF9-CIVIC
Jun 6, 2007 04:48 PM
Black R
Apr 1, 2003 10:39 AM
