Which Tranny for setup and clutch?
Old Feb 11, 2004 | 06:39 AM
incognitoracerr's Avatar
Default Which Tranny for setup and clutch?
Sup All...I am doing an ls/vtec setup and will soon be purchasing the tranny...which tranny should I buy?..should I get the ls tranny or the gsr?..if I get the gsr tranny is the clutch and flywheel purchased according to the tranny you get or according to the block???
Old Feb 11, 2004 | 12:39 PM
Pete_SI's Avatar
Default Re: Which Tranny for setup and clutch? (incognitoracerr)
Gsr tranny would be better, shorter gears. The flywheel is on the block and I think the clutch is the same for every B series tranny. don't quote me on that one.
Old Feb 11, 2004 | 01:30 PM
95 LS's Avatar
To the tranny. Make sure you get the right clutch disc as earlier integra trannies (cable) had a different input shaft. If you're using a hydro tranny I believe the clutches are all the same
Old Feb 15, 2004 | 09:42 AM
AL ASPIRATED's Avatar
get the clutch and flywheel for the specs of the tranny. b series are divided to hydros and cables, meaning cables are the same and hydros are the same.
but if u wanna get good 1/4 mile times, go with b16 tranny, short gears. but if u daily drive it go with gsr.
OBDII Integra
Sep 11, 2009 08:56 PM
i heart honda
19
Feb 5, 2009 05:15 PM
6shootahorsenamedtrigga
Aug 8, 2004 11:17 AM
yaoming
Mar 23, 2003 06:34 PM
Big Teggie
May 13, 2002 02:57 AM
