timing ?
Old Jan 1, 2003 | 08:31 AM
spookhatch24's Avatar
Default timing ?
alright i know how to set ignition timing but if u install high compression pistons how do u know what to set the timing at i know u will have to retard it but
Old Jan 1, 2003 | 08:41 AM
eg6ajk's Avatar
Default Re: timing ? (spookhatch24)
if you install high c/r piston it doesn't necessary mean you need to retard the timing. it depends on many things. first ocatne of gas you're running, head design, overall fueling/ignition maps and much more.
timing should be set at the highest point without getting any pining or detonation, where is that you ask? that comes with tuning and your setup, experiment use your judgment.
spoolingb20
Apr 26, 2006 10:46 AM
infinate bound
Mar 18, 2004 10:35 AM
John
Oct 26, 2001 12:54 PM
John
Oct 25, 2001 10:49 PM
