Throwing Codes!!!
Old Mar 9, 2003 | 04:28 PM
its WANG yoO's Avatar
Default Throwing Codes!!!
92 ls swap in 90 Dx hatch...
throwing codes
4-crank position
7-TPS
14-EACV(idle air control valve)
16-fuel injectors
how the HELL do i fix this???
Old Mar 9, 2003 | 04:39 PM
Timmayeg's Avatar
New User
Default Re: Throwing Codes!!! (VTEC93hatch)
dude id love to help but its so hard with out being there and looking for myself
Old Mar 9, 2003 | 04:42 PM
Default Re: Throwing Codes!!! (Timmay)
i don't know what to do......
Old Mar 9, 2003 | 05:54 PM
poison's Avatar
get your *** to ghey utah so me and timmay can look at it
Old Mar 9, 2003 | 05:55 PM
poison's Avatar
did you convert to mfpi?
Old Mar 9, 2003 | 06:13 PM
Timmayeg's Avatar
New User
Default Re: Throwing Codes!!! (poison)
so hard to tell someone how to check ****, if i was there i could look at it and tell you the problem, just trace all your wires, check all connections, make sure everything is plugged whre its supposed to be, etc..
good luck
Old Mar 9, 2003 | 07:23 PM
ok...
no more 7,14,16 codes...just CODE 4...crank position sensor....
but the thing is...it runs like a raped ape for alittle...then check engine light comes on....and it runs like ****...breaks up at anything over half throttle....and the ecu flashes 4 quick flashes...maybe the crank position sensor is going bad????
tell me what you guys think.................
over all...that thing rips!!!
1st gear...starting off....break the tires loose around 5 grand...2nd and 3rd rip ***...
poison and timmay...i wish i was out west...better than her...****** SNOW!!!
thanks guys!!!
Old Mar 9, 2003 | 08:45 PM
help!!!
Old Mar 9, 2003 | 09:25 PM
Kamin's Avatar
well did you wire the CKP sensor to the ecu?
no?
theres your problem.
Old Mar 10, 2003 | 07:38 AM
Default Re: Throwing Codes!!! (Kamin)
CKP sensor? wtf is that? lemme know...
what color are the wires...and what pinouts do they go to...???
where on the dizzy do the wires from ecu go???
[Modified by VTEC93hatch, 4:45 PM 3/10/2003]
Old Mar 10, 2003 | 09:36 AM
Newman's Avatar
New User
[QUOTE]CKP sensor? wtf is that? lemme know...
QUOTE]
CKP = Crank position sensor (just like I told yah on AIM )
CKP-M = White wire on distributor - goes to B12 on the ECU
CKP-P = Orange wire on distributor - goes to B11 on the ECU
Make sure those are wired up properly.
Old Mar 10, 2003 | 09:23 PM
Default Re: Throwing Codes!!! (Newman)
FINALLY!!!
well i got it running right...finally!!!
VtecVillian came up with this: use shielded wire for the CKP wires from the dizzy to the ecu...i did that...grounded the center wire...and now it runs perfect..NO codes...and No spittin and sputterin....thanks everyone for your help!!!
now i just gotta put the ****** back together....
ph0shizzle
May 13, 2006 08:36 PM
idriveadelsol7
Aug 29, 2005 09:29 PM
scsheong
Nov 22, 2004 10:22 AM
Clydsdal
Sep 21, 2003 08:15 AM
B_1_8_hatch
Aug 12, 2002 07:41 PM
