throwing a code, map sensor
Old May 15, 2003 | 09:37 PM
braatenscott's Avatar
Default throwing a code, map sensor
Hey well i have a 94 civic ex with a b16 swap and it was runnin fine and now all the sudden it throws code 3 the map sensor code and runs like ****. well i tried the map sensor off my other civic and reset the ecu and same crap. well i read my haynes manual and it said to check the volts between the white and green/white wire and its not even close to 5volts.. and its suppose to be i guess. anybody else have any trouble like this!? any help would be appreciated thanks guys
Old May 16, 2003 | 09:03 AM
Default Re: throwing a code, map sensor (braatenscott)
any suggestions?
Old May 16, 2003 | 12:03 PM
bossman032's Avatar
try a Ingerta Map Sencor that should work like a 92-93.
if its OBD1!!
thanks let me know if that works!!!
Old May 16, 2003 | 01:17 PM
b16hybrid's Avatar
found the problem! one of my wires came of the vtec afc from the computer
mr2turbo007
Apr 23, 2012 06:22 PM
tek9_ej2
Apr 10, 2010 05:13 AM
FSUseminoleEM1
Feb 19, 2010 08:34 AM
FSS13foxtrot
Jan 20, 2008 06:23 AM
