Throttle Position Sensor Wiring
Old Dec 14, 2005 | 12:39 PM
Combustion Contraption's Avatar
Default Throttle Position Sensor Wiring
Upon installing my latest mod, i was required to use a different type of throttle position sensor, so i had to splice in a new connector on the harness side. Simple enough. So i took a look at the wiring diagram and it seemed simple enough. Here is what i have to work with so far. This is a view of the new throttle position connector next to the stock honda wiring diagram.
So this is the way i figured it should be wired up.
Now, when i run the car at closed throttle hondalogger states im at 95% throttle, as i rev, the number drops in percentage. So basically, somethings backwards. But looking at the diagram i dont see what it could be. Any help is appreciated, thanks.
Old Dec 14, 2005 | 02:11 PM
Using a DVOM i measured the voltage at the ecu and where i should be getting .45v at closed throttle, im getting near reference voltage, right around 4.6v. As i depress the throttle, the voltage drops to around 1.3v. Thats the opposite of what it should be doing! If i accidentally switched the ground and +5v wires, would this be a symptom?
Old Dec 14, 2005 | 02:19 PM
teler86's Avatar
Default Re: Throttle Position Sensor Wiring (LsVtec92Hatch)
reverse power and ground, put like a 5 amp fuse on the power and try it that way
Old Dec 14, 2005 | 02:23 PM
Im not going to do that unless im sure that reversing them in the first place would have caused this symptom.
Old Dec 14, 2005 | 02:42 PM
Slopoke's Avatar
Default Re: (LsVtec92Hatch)
Is that pic of the connector from the wire side or pin side?
If its from the pin side, then its backwards.
Old Dec 14, 2005 | 02:44 PM
Good point. I assumed it was from the connector side. Im just going to reverse the + and - and see what happens.
Old Dec 14, 2005 | 03:09 PM
Slopoke's Avatar
Let us know!
Old Dec 14, 2005 | 03:59 PM
Ok, just got done and thats what it was. I reversed the + & - cuz i was looking at the diagram upside down, so to speak. Now it reads right where it should. What a rookie!
Old Dec 14, 2005 | 05:17 PM
Slopoke's Avatar
Good job, man.
Old Dec 14, 2005 | 06:02 PM
SteveoBA8's Avatar
Default Re: (Slopoke)
dont you love your dvom
Old Dec 14, 2005 | 08:55 PM
teler86's Avatar
Default Re: (SteveoBA8)
glad to see that you got it taken care off
TwoKSiR
Jun 14, 2008 11:06 AM
valentine97
19
Jan 15, 2008 10:33 AM
Dec 14, 2005 04:04 PM
