Throttle body question
Old Sep 5, 2012 | 12:12 PM
jayeghatch's Avatar
Default Throttle body question
So I have a sec gen b16a, it has the tb with no map sensor an I need to run one.
So I pick up a b18b1 tb from the junkyard. Will the b18b tb bolt up to my stock manifold? Thanks for the help
Old Sep 5, 2012 | 12:21 PM
jdmh22eg2's Avatar
Default Re: Throttle body question
Yes all b series oem tb's are same size expect for ITR. They all mounst same way also, only prob you have mixing and matching is one off a 94-01 gsr with snail style intake mani.
Old Sep 5, 2012 | 12:26 PM
jayeghatch's Avatar
So the tb from the b18b1 will work find with my manifold
Old Sep 5, 2012 | 12:38 PM
Fnix's Avatar
yes it will, what junkyard are you at where you find b18's??. Only honda engines I can find here are d13,d15 and even they are ripped apart
Old Sep 5, 2012 | 12:42 PM
jayeghatch's Avatar
In Ventura county
Old Sep 5, 2012 | 02:57 PM
jayeghatch's Avatar
Another question.
What is the difference from sohc injectors to dohc are they similiar cause I'm usin my sohc on the b16 cause the harness wouldn't work on the injectors the motor came with
Old Sep 5, 2012 | 03:12 PM
jdmh22eg2's Avatar
Well from my memory vx/cx obd1 are less cc than sohc/ls/gsr what have you. So as long as you dont use cx/vx inj, any other sohc inj is same as b series inj
Old Sep 5, 2012 | 05:16 PM
jayeghatch's Avatar
I have a d15b, an trying to use them on b16a
Old Sep 5, 2012 | 05:17 PM
jayeghatch's Avatar
An it's a dx model
Old Sep 5, 2012 | 10:45 PM
jbpnoman's Avatar
The DX D15B uses 240cc injectors. The CX/VX non-vtec D15B uses 190cc injectors. The second gen B16A uses 240cc injectors.
Assuming you have the vtec D15B, your injectors should be a plug and play affair.
Old Sep 6, 2012 | 12:19 PM
jayeghatch's Avatar
Well I just got the d15b block an head an use my dx intake manifold from my d15b7, how can u identified the inj, what would happen if mine are the 190cc an I used those
Old Sep 6, 2012 | 12:45 PM
jdmh22eg2's Avatar
Well assuming your dx mani/inj had never been messed with they are same ones that are used on a b16. No way to tell. If you happen to have cx/vx ones it would run a tad lean, how much i have no idea. But then again the computer via map and o2 might try and compinsate (idk tho just a guess)
Old Sep 6, 2012 | 12:48 PM
jayeghatch's Avatar
Will see how it run when I install the new tb.
Old Sep 7, 2012 | 03:05 PM
jayeghatch's Avatar
so i install the used tb with map an tps sensor. an now when i try to rev the motor it boggs down like if it wants to die.
i try it with a p30 an a p28 sohc vtec an it does the same thing. any ideas why its doing this? thanks for the help
Old Sep 7, 2012 | 03:49 PM
jdmh22eg2's Avatar
Map and tps plug switched? Very easy to do and almost every person on here has done it
Old Sep 12, 2012 | 03:48 PM
jayeghatch's Avatar
So I install the used tb with map an tps sensors. An I let it warn up an it has a high idle an when I rev it high it wants to bogg out.then I try to get the codes an the cel doesn't blink the srs light blinks instead
JasonHi
Jun 25, 2009 10:00 PM
JasonHi
Jun 23, 2009 12:58 PM
seanc520
Aug 20, 2008 06:41 PM
stoned_sol
Jul 7, 2005 03:07 AM
New Image
Jun 29, 2004 08:56 AM
