Swapping a swapped civic
I am swapping a b16 sir 1 into a 1990 civic si hatch.
The civic already has a d16y8 from a 2000 civic.
The ecu is a pm6.
I also noticed a RPM activated switch on the fire wall wired into the vtec sol.
The transmission says L3-2038383.
The manifold says PGM-FI.
I don't know if any of this is going to make the swap easier but i just need to know what I will need to complete this swap.
will the trans work?
Will the axles work?
Will the mounts work?
thanks in advance.
The ecu is a pm6.
thanks in advance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC »</TD></TR><TR><TD CLASS="quote">d and b dont mix buddy</TD></TR></TABLE>
Exactly.
Exactly.
the transmission, mounts, shift linkages, axles, etc. will not work.
You can however use the PM6 ECU and the rpm activated switch to lug the car around until you get a properly chipped PM6 with b16 maps, or the correct PR3/PW0 ECU. I wouldn't reccommend driving the car hard or at high rpm for extended periods of time.
I recently chipped a friends PM6 ECU to run his B16A in an 88 CRX HF. I copied PR3 maps over to the PM6 code and smoothed the VTEC transition and it runs very well.
89civicb16a1
May 16, 2006 02:22 AM
O16581724 5 2 5
May 4, 2006 08:01 AM
