Swapping question...
Old May 31, 2002 | 02:40 PM
brent_G's Avatar
Default Swapping question...
Alright i have a b16 second generation that im putting in my 92 CX hatch...NO one seems to know off the top of their head what stock mounts i can use to do the swap...Does anyone out there know? Plus i need the distributor...I need to know the code to order one. Cause there is two that i can choose from. So if i can get the code that would help alot. So can anyone help me?
please! id appreciate it alot...
Old May 31, 2002 | 07:04 PM
JV's Avatar
JV
Who?
Default Re: Swapping question... (screamincivik)
You can use all your stock mounts, except the "timing belt" or upper driverside mount. You must use the Bseries mount there. I would also suggest you invest in some polyurethane mount inserts as the stock Dseries mounts will be alittle on the mushy side with the B motor........
justseeingifitistaken
Aug 20, 2006 09:44 PM
jadsi420
Aug 11, 2005 07:16 AM
jdm4life!
Jul 30, 2005 09:53 PM
crex23
Oct 11, 2003 06:02 PM
DJ_SaNdOz
Feb 10, 2003 09:10 AM
