swaping engine harness...... engine still in the car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua »</TD></TR><TR><TD CLASS="quote">here is what i'm thinking about doing.
car is a 2000 civic ex
OBD 1 gsr motor
we did use a OBD2 99si harness but wiring got all messed up.
So what we are thinking about doing is simply just swaping the old OBD 1 harness back on to the motor.</TD></TR></TABLE>
The OBD1 Integra harness will not work at all in a 2000 EX. You need to use a 1 piece 99-00 Civic harness for plug and play or a 96-98 with an OBD2B adapter harness. The Integra harness is a 2 piece design and won't work, not even close so don't waste your time.
OBD 1 gsr motor
with the OBD1 engine harness you will need the whole sub harness from inside the car(which runs to the guages, relays, tailights, fuel pump, etc
Just get a good UNCUT 99 SI harness and start over. Or use the EX harness.
then no matter what, you need to run the OBD1 ECU to get rid of the crank angle
I would just an uncut EX or Si engine harness, and adapt it to the GSR engine. You can convert the GSR motor to OBD2 by getting an OBD2 oil pump with the CKF sensor on there.
I would recommend just converting to OBD1 and convert the OBD1 distributor to the OBD2 plug with the diagram I sent you via IM (assuming this is pennie's car?)
Use that with an OBD2a > OBD1 jumper harness and an OBD1 P72 ECU.
thanks poison your the man. We will see how this weekend goes. Yeah pennies ride is at my crib and hes back in school in WI..... we'll let you guys know
TwoKSiR
Dec 18, 2008 10:28 AM
IN VTEC
Jul 27, 2003 08:01 AM
