swap trouble
Old Jan 21, 2006 | 09:40 AM
1slow_hatch's Avatar
Default swap trouble
i have a 92 civic cx with a 95 f22b1 from an ex accord. Now im using the ecu from the accord and im throwing a code. Its one long flash another long flash and two short flashes. Now i thought that was 22 which is vtec pressure switch but i hooked it up to the two available slots in the shock tower harness like the forum said and i wasnt sure if it was 12 and the first flash ment obd1 and 12 is egr and the forum said the p28 ecu doesn't look for the egr. So any ideas or help would be greatly appreciated.
Old Jan 22, 2006 | 01:49 PM
Jago's Avatar
Default Re: swap trouble (1slow_hatch)
was the stock engine a vtec if not you probably need to run the wires for vtec all
the way to the ecu.
bobbyboy545
Mar 19, 2024 12:43 PM
95halx
Mar 20, 2011 01:49 PM
irishbobby23
Jan 1, 2008 07:22 PM
tmkpres
Feb 6, 2003 04:06 PM
tiiiteSedan
Jun 19, 2002 02:15 PM
