Swap Question?????
Old Dec 12, 2006 | 06:34 PM
Hatchman98's Avatar
Default Swap Question?????
Ok I just Got doen doing a b16a jdm motor into a 99 Civic EK Hatch. I have all the fluids in and the lines and the harness are hooked up. Battery is also hooked up and the starter is grounded. When i put the key in the lights and all the electronics work but the car does not start. It doesnt even make a noise there is no start or even a crank on the turn of the key any ideas???? Thanx
Old Dec 13, 2006 | 02:23 AM
who-got-rice's Avatar
Default Re: Swap Question????? (Hatchman98)
ok check your grounds, especially the one on your tranny from the pass frame rail, make sure the surfaces are clean where they meet, do you hear the main relay click when you depress the clutch, are your fuses all good....
Old Dec 13, 2006 | 04:32 AM
Hatchman98's Avatar
Default Re: Swap Question????? (who-got-rice)
ya i do hear the relay click when i turn the key ill double check the ground on the trans..
Honda_bed
Apr 22, 2014 12:22 AM
invisible
Feb 13, 2009 05:34 PM
sabot808
Apr 21, 2007 09:37 PM
cbstudd77
Dec 20, 2006 07:40 PM
KyleVA
Sep 6, 2006 03:13 AM
