swap problems
Old Apr 8, 2004 | 06:53 AM
doug piston's Avatar
Default swap problems
hi. im new to this board and hondas. i have a 92 cx hatch with a sir2 swap. swap went fine fine except that when im driving after the car warms up the cel will come on sometimes it takes 30 mins and others it takes 5. i noticed it takes longer when it cold outside. im running a p30. anybody ever have this problem? or does anybody know what it is?
Old Apr 8, 2004 | 06:57 AM
Default Re: swap problems (doug piston)
also it still does hit v tec when cel is on. thought it mybe purge valve which i have connected through the fuel pressure regulator. does it possibly need moree vacuum then that
Old Apr 8, 2004 | 07:17 AM
VTECVillain's Avatar
It's probably the O2 sensor CEL. CX models have a 1 wire O2 sensor and need the wiring converted to accept the 4 wire O2. Have you jumped the service connector to see what CEL's the ECU has stored?
Old Apr 8, 2004 | 12:53 PM
Default Re: swap problems (VTECVillain)
no. can i while the car is running cause it goes out once i turn off the car. i have done the 4 wire o2 sensor
Old Apr 8, 2004 | 08:18 PM
Echo7847's Avatar
Once the cel comes on the code is stored in the memory. Jump the service connector and read the code, make sure you have the car off, and then just turn the key so the battery comes on dont start the car. Long flash = 10, short flash = 1.
project91crxsi
41
Oct 30, 2009 04:56 PM
vietnameseone
Jan 19, 2009 06:07 PM
avex
Oct 12, 2005 06:07 PM
vietpr1nce
27
May 12, 2003 06:12 PM
