SWAP Problem!
Old Nov 5, 2017 | 05:16 AM
Antonioej8's Avatar
Icon4 SWAP Problem!
Hi, I just registered in the forum!
Right now I'm doing a swap to an ej9 (d14z2-obd2b) and I've put a d16y8 (obd2a)
The problem is that the gas pump does not work ...
I changed all the wiring behind the dashboard, I have a p28 with obd2a / obd1 conversion harness, the main relay works perfectly and the engine checks perfectly.
The fuel pump worked perfectly with the d14 but when I mounted the d16 it stopped working.
Does anyone have an idea that it may be failing?
Thanks and greetings from Spain, forgive my English I am using a translator
phatboyzef2
26
Feb 28, 2011 12:44 PM
Skunk.Werks
Jun 11, 2010 05:42 PM
KyoCivic98
Jul 29, 2009 01:31 AM
DreamOfTheFlood
Oct 3, 2005 12:50 PM
89 JDM CRX
Mar 24, 2004 06:22 AM
