Studdering...like it is not getting fuel. HELP
Old May 6, 2002 | 09:45 AM
jdmciviceg's Avatar
New User
Default Studdering...like it is not getting fuel. HELP
I just recently put an ITR motor in my hatch and it has started studdering like it is not getting fuel. It has a tendency to backfire also. I have already replaced the fuel filter. The fuel pump is the factory CX but from what I hear, it is the same as the GSR pump. The idol also surges up and down by about 100 rpm. I am using a p72 ECU from a GSR. I sent off a p30 to get the stage 2 hondata and hopefully that will help some of the problems. Any suggestions on what it might be would be greatly appreciated.
Old May 6, 2002 | 12:06 PM
#417R's Avatar
Default Re: Studdering...like it is not getting fuel. HELP (jdmciviceg)
Quick question, does it have this fuel problem all the time or does it quit after a while?
Old May 6, 2002 | 12:19 PM
EVOCELICA's Avatar
New User
Default Re: Studdering...like it is not getting fuel. HELP (b20zkid)
if it's back fireing it's getting enough fuel. Did you try replacing the plugs and the ignition coil
Old May 6, 2002 | 02:54 PM
jdmciviceg's Avatar
New User
Default Re: Studdering...like it is not getting fuel. HELP (EVOCELICA)
The car pretty much does it all the time. I have not replaced the coil or the distributor. It did not do it when I first put the motor in. It just started a few weeks ago.
Old May 6, 2002 | 03:29 PM
jdmciviceg's Avatar
New User
I just went and pulled the distributor cap and it looks fairly worn so I went to swap it with my roommates 95 b18c1 cap. His cap is slightly different than mine. The top screw holes on his was slightly wider than mine. Arn't all B series caps the same? I'm not sure what motor my distributor came off of since my motor was converted over to obd 1 when I bought it.
Old May 6, 2002 | 04:13 PM
EVOCELICA's Avatar
New User
I don't believe all the caps are the same, try swapping the coil or getting a msd cap and an external msd coil. Also try swapping the plugs.
Mine did the same thing like 2 months after the swap just changed the plugs and it was fine
Old May 7, 2002 | 04:51 AM
jdmciviceg's Avatar
New User
I changed the distributor and it did not help. Going to try the fuel pump and take out the V-AFC tonight and see if it helps. Plugs tomorrow if it does not resolve it. Anything else that I maybe over looking?
Old May 7, 2002 | 07:56 PM
#417R's Avatar
Are you throwing any codes or anything since this happened? Also, when you was running right, do you remember if you added anything to the car or changed out anything that would cause this problem. By the way, have you checked your ignition timing?
Old May 7, 2002 | 09:12 PM
jdmciviceg's Avatar
New User
Well, I put in a different fuel pump and changed the plugs. No difference. It still studders. I then took out the V-AFC and now the check engine light comes on when I get into Vtec. Any clues on what it could be?
[Modified by jdmciviceg, 10:12 PM 5/7/2002]
Old May 8, 2002 | 05:06 AM
jdmciviceg's Avatar
New User
ttt
Old May 8, 2002 | 11:00 AM
EVOCELICA's Avatar
New User
try a different ECU
Old May 8, 2002 | 07:20 PM
jdmciviceg's Avatar
New User
try a different ECU
The hondata will be here in a few days. I am replacing the wiring harness and the O2 sensor tomorrow. The vtec solenoid does not a an oil pressure switch. Do you think the p30 or p72 will not work correctly with a vtec solenoid without the oil pressure switch?
[Modified by jdmciviceg, 8:21 PM 5/8/2002]
Old May 8, 2002 | 11:27 PM
slammed_93_hatch's Avatar
i had a simular problem check your plug wires and your cap to make sure there is no corosion up in there
Old May 9, 2002 | 01:13 AM
NWPNOMORE's Avatar
Banned
Default Re: Studdering...like it is not getting fuel. HELP (slammed_93_hatch)
I had a similar problem just recently. My timing was off a notch, causing my motor to act sort of like what you described. Just a thought.
Old May 9, 2002 | 04:33 AM
jdmciviceg's Avatar
New User
Default Re: Studdering...like it is not getting fuel. HELP (NWP4LIFE)
It looks like it maybe off a tooth on the timing. Going to move the timing belt today and see if it helps. Thanks.
Old May 9, 2002 | 07:37 AM
NWPNOMORE's Avatar
Banned
that's your problem mn, a tooth off is not good. Readjust it and your car will run smooth.
Old May 9, 2002 | 11:21 AM
Fez's Avatar
Fez
Try taking your donkey out of the tail pipe, that should work.
Old May 9, 2002 | 09:10 PM
jdmciviceg's Avatar
New User
Changed the wiring harness and the timing. The motor still surges but it idols smoothly. Now when the car gets into vtec, the check engine light comes on (code 22 for vtec oil pressure sensor). The japanese ITR motor does not have a vtec oil pressure sensor. Do you think because I do not have an oil pressure sensor it will throw this code and cause it to surge? I am going to get a vtec solinoid with oil pressure sensor tomorrow and try it. Any suggestions?
Old May 14, 2002 | 10:11 AM
98DC2's Avatar
Totally awsome pics! Nice touch w/ the f#%&ing hefer....need I say another word
bochnak
May 25, 2007 04:03 AM
go2sleep
May 4, 2007 07:19 PM
Mariokdiddy
Jun 28, 2006 01:21 PM
junya16
Mar 13, 2003 09:14 PM
chiefvtec
Mar 3, 2003 04:23 AM
