Strange Engine code
Ok all the past codes I have had have come on and stayed on. Once they are there I can jump the ecu and find whats wrong and fix it. Now I am getting a code. Not there when I start the car, comes on after round 5 minutes. Goes off when I turn the car back on. Try to jump the ecu and I get no code at all.
Things I just did:
Removed secondaries assembly and map sensor to install mc/booster and prop valve
Disconnected header to fix rusty flange.
Whats going on?
Things I just did:
Whats going on?
Must not have used a decent paperclip. Tried it and got nothing no code or anything. Ive done it before and of course got the code and all. Correct me if Im wrong: In the past when I ve had a code (knock sensor etc. Once the ecu saw the problem the light stayed on til I fixed it and reset the ecu. This code just comes on and goes off. Whats going on? I wish my friend that pulled all the wires out of the O2 sensor connector wasnt out of town so I could make him crawl under there and fix it. Ive been under my car enough lately.
Anyone have proper harness to sensor wire colors etc for O2 sensor.
Didnt go on at first so I figured he put them back in there right.
delsol93
Jun 21, 2001 02:54 PM
