Still having issues with restarting
Old May 7, 2002 | 10:48 AM
1hottEG6's Avatar
Default Still having issues with restarting
Ok, so yesterday i got a lot of help from some techs. However nothing seemed to work. I basically used a brand new ECT and my engine still won't start when hot. So today i learned that if I take out the ecu fuse and let it sit for a minute, it will start.? any suggestions..thanks
btw
-my fuel pump does turn on when i when i turn the key(so im thinking the relay is good)
-engine cranks, but does not turn over
-and my radiator fan is not turning on sometimes...?
Old May 7, 2002 | 07:49 PM
#417R's Avatar
Default Re: Still having issues with restarting (B20eg-T)
After you reset the computer and changed out the ECT sensor did you still get the code 6?
Old May 8, 2002 | 12:38 AM
tinkerbell's Avatar
Default Re: Still having issues with restarting (b20zkid)
if you did get the code, have you checked the wires from the ECT to the ECU?
outtacontrolsol
Acura TL, RL & ZDX
Jan 24, 2011 08:20 PM
johnwohl
17
Apr 6, 2009 05:58 AM
nemeii
Aug 10, 2008 03:01 PM
1hottEG6
May 8, 2002 06:47 AM
1hottEG6
May 7, 2002 02:17 PM
