sleeper b16
Old Feb 12, 2009 | 01:11 PM
adam00's Avatar
Default sleeper b16
i have been thinking about making a sleeper b16. I want to put a ls crank in a b16 block but i have been reading that you will need custom pistons or rods and that you have to notch the block to make the crank fit. does anyone know how reliable this setup be and will the be the same displacement as a ls vtec even though you will need custom pistons or rods to stop the pistons from hitting the head?
Old Feb 12, 2009 | 01:24 PM
LA_HONDAS's Avatar
Default Re: sleeper b16
you need custom pistons and stock size ls rods
ericksracing sell the pistons but they are 11.5:1 c/r so if you a lower or higher c/r just call them
Old Feb 12, 2009 | 02:21 PM
adam00's Avatar
to put a ls crank in a b16 block what length (mm) connecting rod is needed so i can use oem pistons
Old Feb 12, 2009 | 03:26 PM
adam00's Avatar
i went on to zealautowerks and did there b series calculator it said with a b16 block and head with ls crank, oem 3 layer head gasket, b17 rods, custom pistons 82mm (6.19 Dome (cc)26.19 Comp Height (mm))
i would have a Static Comp Ratio 11.94:1
Effective Comp Ratio 11.84:1
Displacement 1880.04cc
Rod / Stroke Ratio 1.48:1
Piston-to-Deck Height 0.022in
how does this setup sound
Old Feb 12, 2009 | 03:30 PM
LA_HONDAS's Avatar
you cant use oem pistons have to use custom pistons
the pistons will bottom out with shorter rods
buy some used ls eagle rods and ericksracing pistons and call it a day
Old Feb 12, 2009 | 03:31 PM
LA_HONDAS's Avatar
that setup wont work
Old Feb 12, 2009 | 03:34 PM
adam00's Avatar
how reliable will this motor be and what rpm would be safe to take it to?
Old Feb 12, 2009 | 04:57 PM
LA_HONDAS's Avatar
10krpm wont be a problem with a setup this you just have to get it tuned
you mite want call ericksracing about this setup
SoCal EJ1
Dec 13, 2008 12:38 AM
CTR_B
Oct 17, 2008 04:19 PM
NACvicSi
Apr 22, 2007 06:02 PM
CO_CReX
Apr 26, 2006 11:03 PM
mrbsponge
Apr 28, 2005 08:01 PM
