shift problem b16a2
i jsut got a b16a2 in a 94 civic coupe .its was an auto to 5spd swap and now i have shifting problems. the gears go in really rough when driving but at idle its fine. i thought it might be the bushing or motor mounts? do u guys know which shift linkage i should use and how can i tell the difference between a civic linkge and an integra linkage? thanx
You can use the Teg linkage like On Point said, or you can use 99-00 Civic Si linkage too.
Also don't forget to properly bleed the clutch hydrolics. Even if the linkage is perfect, air in the clutch lines will cause shitty clutch response.
TylerB
Mar 24, 2010 12:42 PM
9three4drintegra
Aug 14, 2005 09:21 AM
