I am having problems with my gsr cluster in my 90 crx si. I have every thing working accept the speedo and vtec plus bat light.
i do have the electronic vss its hooked up the speedo works but no vtec and the bat light seems to blink when i am driving can some one help just need to butten this biznatch up and get her done. thanks for all help
sounds like the ECU dosent have the speedo signal, it needs it to engage vtec.
as for the battery light, check all your connections at the alternator, plugs, and cluster. probably a bad connection.
cool thanks got it all working, the only thing now is the gas guage is off.
I mean it works but i filled the car up all the way and it only showed like 3/4 of a tank. Is there a way to fix that. There is nothing worse than trying to guess how much gas is in your car could make for a rough day.
thanks
thanks
