the #'s on B20 nonvtec
Old Dec 29, 2003 | 11:50 PM
hybrid92b20's Avatar
Default the #'s on B20 nonvtec
I don't know if this already been addressed or not but I have a B20 with a LS head for now and I haven't been able to go to the dyno or track yet. My question is does anyone know what this settup is putting out just the way it is with hp header, aem cai, b&m fuel pressure reg., bbk intank pump, act3 clutch, 95 delsol si tranny. If anyone has any idea and any charts or anything like that to back it up I would really like to know, I'm getting ready to start building it and I would like to know what I'm starting out with. THANKS
Old Dec 30, 2003 | 01:02 AM
Hybrid96EK's Avatar
Default Re: the #'s on B20 nonvtec (hybrid92b20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybrid92b20 &raquo;</TD></TR><TR><TD CLASS="quote">I don't know if this already been addressed or not but I have a B20 with a LS head for now and I haven't been able to go to the dyno or track yet. My question is does anyone know what this settup is putting out just the way it is with hp header, aem cai, b&m fuel pressure reg., bbk intank pump, act3 clutch, 95 delsol si tranny. If anyone has any idea and any charts or anything like that to back it up I would really like to know, I'm getting ready to start building it and I would like to know what I'm starting out with. THANKS </TD></TR></TABLE>
The LS head is exactly the same as a stock B20 head as far as I know, so you aren't picking up any additional power from it. I would say whatver your stock rating is + maybe 10 crank power would give you an idea. Check out http://www.importreview.com for dynos of various setups. I think they might have one of stock or near stock B20's.
Old Dec 30, 2003 | 06:16 AM
Default Re: the #'s on B20 nonvtec (Hybrid93Eg)
ok i checked out that site and the only #'s they had were from B20vtecs I'm looking for nonvtec stats, but thanks for the input
Old Dec 30, 2003 | 03:17 PM
Skip01's Avatar
Is it a B20B or B20Z?
The LS cams will give you a lil better top-end.
Your prolly around 130-135 at the wheels.
Old Dec 30, 2003 | 03:21 PM
BlueTeg's Avatar
Default Re: (Skip01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skip01 &raquo;</TD></TR><TR><TD CLASS="quote">
Your prolly around 130-135 at the wheels.</TD></TR></TABLE>
Old Jan 20, 2004 | 01:17 PM
untitled's Avatar
Default Re: (BlueTeg)
i thought the ls head was only for 81mm bore and the b20 was for 84 which would make the ls head give it more compression? am i right?
Old Jan 20, 2004 | 02:35 PM
BlueTeg's Avatar
Default Re: (Vetter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vetter &raquo;</TD></TR><TR><TD CLASS="quote">i thought the ls head was only for 81mm bore and the b20 was for 84 which would make the ls head give it more compression? am i right?</TD></TR></TABLE>
Nope.
The LS and B20 share the same P75 head casting.
Old Jan 20, 2004 | 07:37 PM
theSQad's Avatar
just wondering but .. why build a nonvtec b20 swap ? why not ditch the LS head and go for a SI head ... ?
Old Jan 20, 2004 | 07:50 PM
Skip01's Avatar
Default Re: (thesqad127)
B20B:
98 B20B stock head and block, 94 P75/LS ecu
Intake: GSR stock cone filter and tube (no airbox), LS intake manifold, 64mm TB
Ex: GSR exhaust manifold, test pipe, Greddy BL exhaust
B20Z:
98 B20Z stock head and block, 94 P75/LS ecu
Ex: JDM 4-1, test pipe, Greddy BL exhaust
Also this is at the wheel hp,so there factory specs should be a lot higher.
Old Jan 20, 2004 | 08:18 PM
theSQad's Avatar
so thats a non vtec b20 block .. compared to a vtec b20 block with gsr manifold ... hmmm ?? so are non vtecs better for all motor build ups ??
Old Jan 20, 2004 | 08:39 PM
bambbrose's Avatar
they are both non vtec, the only difference is one is a b20b (96-98 crv) and the other is a b20z (99-01 crv)
the b20z has higher compression, 9.6:1 compared to 8.8:1 I think
Old Jan 20, 2004 | 08:54 PM
BlueTeg's Avatar
Default Re: (bambbrose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose &raquo;</TD></TR><TR><TD CLASS="quote">they are both non vtec, the only difference is one is a b20b (96-98 crv) and the other is a b20z (99-01 crv)
the b20z has higher compression, 9.6:1 compared to 8.8:1 I think </TD></TR></TABLE>
You are correct.
Old Jan 20, 2004 | 09:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesqad127 &raquo;</TD></TR><TR><TD CLASS="quote">just wondering but .. why build a nonvtec b20 swap ? why not ditch the LS head and go for a SI head ... ?</TD></TR></TABLE> It's kinda a $ thing, plus I'd like to see what I can get out of it first& maybe by the time I get done w/ the all motor non-v I might decide to boost instead of v-tec head, We'll see. Anyways thanks for all the input ya'llve been very helpfull. THANKS
Old Jan 21, 2004 | 10:41 AM
theSQad's Avatar
cool .. thanks for clearing that up ... hmm so 99+ b20z is the way to go .. higher compression .. newer block .. thanks yall .. !
ef-b16sedan
Nov 12, 2006 07:27 AM
1995sir
Mar 19, 2006 09:02 AM
b20vtec214
14
May 10, 2005 06:27 PM
integrakilla
Nov 27, 2004 04:21 PM
maxxdout
Oct 24, 2002 11:35 PM
