Running with out a knock sensor, hitVTEC?
Old Sep 16, 2003 | 06:42 PM
Audi A4's Avatar
Default Running with out a knock sensor, hitVTEC?
if im running a obd-2 vtec ecu taht reads a knock sensor, will i have to install a knock sensor in order to hit vtec? or will it just throw the code and still hit it
Old Sep 16, 2003 | 06:58 PM
3minburnout's Avatar
Default Re: Running with out a knock sensor, hitVTEC? (DRAG lll INTEGRA)
The vtec will still engage ,however the timing may be retarded a degree or two
Old Sep 17, 2003 | 05:36 PM
Turbo(less)DB8's Avatar
Without a knock sensor, your car will go into "limp mode." Install the knock sensor and you'll notice a big difference. Been there, done that.
Old Sep 17, 2003 | 06:43 PM
poison's Avatar
VTEC will still work with the KS not working or disconnected.
I would recommend replacing the KS or getting a chip, however.
Old Sep 18, 2003 | 12:03 AM
infinatenexus's Avatar
Default Re: Running with out a knock sensor, hitVTEC? (poison)
can't you just hook up a knock sensor, zip tie it to a bracketand ground it to the fire wall?
SingleCamin
May 19, 2009 08:23 AM
cacahead1
Jun 8, 2005 04:41 PM
codeh22a4
Apr 8, 2004 12:51 AM
