resistor box
look in the FAQ's in the civic forums
if you have a multimeter you can check ohm's if it is p&h injectors it should be around 2-3 ohm if its 10 or higher you dont need a resistor box
but most likely you will need a resistor box look in the civic FAQ's to see how to wire it up
