rebuilding bottom end
Old Jan 7, 2004 | 07:49 PM
Hybrid CRX's Avatar
New User
Default rebuilding bottom end
95 ls motor, its got like 150,xxx.
i got ls rods and some ctr pistons.
What would i need to do to the bottom end to make it fresh and clean? Bore? Hone? And how much would all this cost roughly?
Old Jan 7, 2004 | 08:07 PM
thad
Guest
Posts: n/a
Default Re: rebuilding bottom end (Hybrid CRX)
I would repalce the main oil seal, oil pan gasket, oil pick up gasket, plastigauge the bearings. get new rings if you don't already have them, hone the cylinders, have the deck checked for flatness, if it's off have them shave .010"
don't get the crank polished unless it has scoring (you'll need new bearings)
if you do, make sure to tell the rep at the dealership how much they took of when selecting new bearings.
good luck on your rebuild
_________________________________
100th post
Old Jan 8, 2004 | 12:01 PM
eastbay92cx's Avatar
Default Re: rebuilding bottom end (thad)
You can replace the rings and hone the cylinders yourself with a hone made for a hand drill / drill press. Other than that you could have a shop turn the crank for you if you plan on replacing the bearings. Around here I got quoted at $90 one time for a 4 cyl. crank. Not much money at all if you take care of what labor you can. Again good luck.
Old Jan 9, 2004 | 06:26 AM
ExospeedAMcrx's Avatar
We do this type of block reconditioning all the time. Check out our engine page on our website for a price comparison on how much a shop should charge you.
YOu will see the stage 2 build up includes the OEM pistons with the other necessary parts to rebuild the block properly.
Wil
hayden55
Jun 16, 2016 02:51 PM
vtechjunkie
Dec 1, 2008 07:34 AM
sodacan33
Jun 10, 2004 07:10 AM
HX_Guy
Nov 30, 2001 12:57 PM
