rear engine/tranny bracket?
sup, i'm doing a b16a3 swap into a 4th gen hb using the hcp mount kit and cannot seem to get the engine to line up with the right side tranny mount when i bolt up the rear mount, does anyone know if i'm suppose to use a different L bracket other than the b16a3 bracket, also the mount for the driver side is crooked when i bolt it up to the bracket, i guess i have to get another bracket for it too huh
[Modified by vhd, 8:29 AM 11/9/2001]
[Modified by vhd, 8:45 AM 11/9/2001]
Yeah, you need the rear trans bracket off a 90-93 integra. Put that bracket on first. Also, you will need to notch some of the back of the bracket off so it doesnt hit the frame rail.
Jason,
did u use the 90-93 integra mount thing bracket that holds the mount kit from hcp.. on the driver side as well? cuz i have one from the 94 delsol.. and i tried it and it didnt work.. .. do i take one from the 90-93 shortblock bracket or which one should i used?
also any idea where i can find this in the bay area.. i need it asap.. by sunday.. i need both..
[Modified by Json79, 6:40 PM 11/9/2001]
You will probably need the 1st gen B16a driver side motor bracket....I know that that works, I am not too sure on the 90-93 teggie. I might have the rear bracket....but I am north of Sacramento. Email me if you are interested
Jason
Jason
EFinawesomeman
Aug 5, 2009 11:55 AM
XkjeldorX
Jun 21, 2006 01:49 PM
