AN-R Header!
Old Sep 24, 2005 | 08:38 PM
IGotNoSwap's Avatar
Default AN-R Header!
Hey guys,
I searched and wasn't able to come with any results. anyways, does anyone have any experience with the an-r compact header? Pros and Cons? Fitment Issues? What were your HP gains? Do you run this header open or bolted up?
I am interested in this header for my b18c in my crx.
Thanks.
Edit: Pic for reference.
Old Sep 24, 2005 | 09:53 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: AN-R Header! (IGotNoSwap)
Im currently running this header on my 11.6-1 comp b16a with pro1 cams, excellent header, big gains over stock, and my old jg/edelbrock pro flow header. Make sure you get it tuned, or you will run lean just bolting it up.
Old Sep 24, 2005 | 10:36 PM
mrDFWmechanic's Avatar
crazy *** lookin header
Old Sep 25, 2005 | 06:36 AM
RotiEatter's Avatar
Ditto
I have it on my H22
Old Sep 25, 2005 | 12:25 PM
skunked's Avatar
Default Re: (RotiEatter)
they make good power but they tend to crack welds easily.
RMF is also an option.
Old Sep 26, 2005 | 08:05 AM
IGotNoSwap's Avatar
Default Re: (skunked)
for everyone out there running this header, do you run this header open header, or is bolted up to a cat or an exhaust system. thanks for all the help.
Old Sep 26, 2005 | 11:59 AM
IGotNoSwap's Avatar
Default Re: (IGotNoSwap)
Old Sep 26, 2005 | 08:08 PM
red civic standard's Avatar
I had the compact An-r header with street collector two years ago. Made 191/130 with skunk2 stage 1 cams on a stock bottom end ITR motor. Had to cut my stock crossmember a bit, but not too bad. They had problems with the old ones cracking, but that problem has been taken care of. I ran mine through a 2.5" exhaust.
Old Sep 26, 2005 | 10:33 PM
IGotNoSwap's Avatar
Default Re: (red civic standard)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard &raquo;</TD></TR><TR><TD CLASS="quote">I had the compact An-r header with street collector two years ago. Made 191/130 with skunk2 stage 1 cams on a stock bottom end ITR motor. Had to cut my stock crossmember a bit, but not too bad. They had problems with the old ones cracking, but that problem has been taken care of. I ran mine through a 2.5" exhaust.
that's the **** im looking for. thanks for the help bro. i see you got an EF also, did this bolt straight up to your exhaust system or did you have to weld an extra piece to bolt it up?
what exhaust were you using also? thanks man.
Old Sep 27, 2005 | 03:46 AM
the an-r header does not come with a flang to connect it to an exhaust. You will have to get one welded on. The exhaust was custom. There is definitely some custom lenght adjusting that must be done to an exhaust to make it work.
Old Sep 27, 2005 | 04:46 AM
RotiEatter's Avatar
Ditto
Here is my AN-R on my H22...
Running it out of a 2.5" KTeller exhaust, Magnaflow ES muffler, and Magnaflow resonator. No cat,
Old Sep 27, 2005 | 06:53 AM
IGotNoSwap's Avatar
thanks for all the help guys. all of my questions have been answered. thanks.
da'ee
Feb 14, 2005 01:03 PM
pr3B20pwr
Jan 20, 2005 07:29 AM
