Quick questions about OBD1 engine into OBD0 car!
Old Aug 19, 2004 | 02:01 PM
0ptimus prime's Avatar
Default Quick questions about OBD1 engine into OBD0 car!
Alright guys, this is my first time swapping an obd1 engine into an obd0 car. I have some questions...
First off, we've already purchased the obd0-1 conversion harness so that we can use the P06 (obd1 DX) ecu. OK my question is......What harness do i use on the actual engine?
Do i use the CRX HF harness (obd0) on the OBD1 engine? Or do i use the DX engine harness (obd1).
If i use the DX harness, how do i get it to fit at the shock tower? I know the connections are different.
If i use the HF harness, do all of the sensors and plugs go in the same on the OBD1 engine?
Also, for the ECU pigtail, do i wire the bare wires to the firewall side of the shock tower connections?
Thanx for some input.
Old Aug 19, 2004 | 02:58 PM
Default Re: Quick questions about OBD1 engine into OBD0 car! (0ptimus Prime)
Old Aug 20, 2004 | 08:28 AM
Cnote's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 0ptimus Prime &raquo;</TD></TR><TR><TD CLASS="quote">What harness do i use on the actual engine? Use your old CRX harness. If it is HF then your fine, if you have a DX harness get ready to convert to Multi point1
Take a while to change the plugs over, i wouldn't do it
NO, you'lll have to change out the injector clips, dizzy plugs, convert your HF harness to 4 wire o2 plugs
thats up to you, i personally make all the wires connect to a new shock tower plug set and make a sub harness from the new wires. In your case since it seems like your putting in a DX motor you'll just have to add the 4 wire o2 in. or if your going to go VTEC then you'll have to add 3-4 wires based on your motor
Old Aug 20, 2004 | 09:14 AM
Default Re: Quick questions about OBD1 engine into OBD0 car! (Cnote)
^ you are the man
boomslang
Dec 6, 2010 09:37 AM
Honda_Fanatic
Oct 29, 2007 08:52 AM
E_F_9
Dec 25, 2005 07:36 PM
0ptimus prime
Aug 22, 2004 06:52 PM
0ptimus prime
Aug 19, 2004 02:59 PM
