Question on doing an Automatic EG with a k swap?
Old Feb 5, 2012 | 04:44 PM
camoner's Avatar
Default Question on doing an Automatic EG with a k swap?
I live in a high traffic area, eventually I want to do a k swap on my eg, whihc is an automatic, I would love to keep the automatic, because in all honesty I don't have the patience for manual. But after some searching I haven't found much info, so will it be more complicated then the thoroughly covered Manual K swap? Will I have issues with mounting the transmission, or anything of that nature, any advice is always appreciated.
Old Feb 5, 2012 | 05:02 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Question on doing an Automatic EG with a k swap?
There's a reason for that. Your best bet is researching here. http://www.k20a.org/forum/index.php
Old Feb 5, 2012 | 05:25 PM
94EG8's Avatar
Seagull Management
Moved to hybrid.
I'm not going to tell you it can't be done, but it's probably a lot more trouble than it's worth. Also K-pro is a manual only deal IIRC. Using the stock ECU requires a lot of extra wiring and swapping the fuel tank. Honestly driving a manual, even in a high traffic area is pretty simple.
Old Feb 5, 2012 | 05:57 PM
NOFX's Avatar
H-T White Ops
If you really want a swapped automatic EG you'll probably end up with a B-series. Even then, my friend who did it had a hell of a time with it. Lots of wiring and then I think he went through three or four transmissions before he sold the motor and did a manual conversion with a different swap.
Old Feb 6, 2012 | 04:54 AM
camoner's Avatar
Are there any shops that have this down to a science? I have an evo I don't really want to make this manual, I'm guessing the easiest is a mini swap then, but I'm really not looking to do that.
Old Feb 6, 2012 | 10:34 AM
NOFX's Avatar
H-T White Ops
Have what down to a science?
Old Feb 6, 2012 | 11:10 AM
The Grumpiest
The ultra rare swap he asking about. Yeah, I don't understand the question about a shop either. If you can't find any info on the swap anywhere then why would it follow that there would be a shop that specializes in such a swap?
Old Feb 6, 2012 | 06:48 PM
hondasdohc's Avatar
I know a friend who had an auto h23a vtec 97 ek coupe which was kinda weird but it is probably the difference in wiring to the k that makes it harder but it can be done if you have time and patience.
Old Feb 6, 2012 | 07:16 PM
NOFX's Avatar
H-T White Ops
The 6G and 5G cars have differences in the clearance area for transmission btw. So I've heard, at least. I guess there have been issues fitting auto B-series into USDM 6Gs, but my friend put that auto B-series into his 5G without clearance issues.
Auto B, D, and H-series might fit. Doesn't mean K-series autos will.
Old Feb 7, 2012 | 06:29 AM
The Grumpiest
I thought the post was about a K-series? These are two totally different engines. Have you ever even read what goes into either swap?
Old Feb 7, 2012 | 08:11 PM
hondasdohc's Avatar
I know it's two different engines just saying an h is closer to the k in some ways like the cable for the trans and similar torque and power. I have had various h/f series motors auto and manual and seen auto k trans and they have the similar one cable to shift it so why can't it be done. I have an f22a1 with f20b pistons along with the f22 crank and rods it works perfectly but besides the point i know it's a k he's talking about and it can be done.
Old Mar 25, 2024 | 12:34 PM
Qqabeq's Avatar
qqabeq) Just wondering if you have any more information an auto k24 as in where to get auto motor mounts and axles to fit an eg .
Old Mar 25, 2024 | 10:05 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
You actually use manual mounts. Remember that the right side bracket, which differs between manual and automatic chassis, has to be CUT OFF of the frame rail and a replacement bracket is bolted in... thus, it makes no difference which mount type you started with, you end with what you need.
Ghunt521
Jan 12, 2012 08:23 PM
95accordex1
Jul 6, 2008 05:29 PM
iwontanek9
Sep 27, 2007 11:33 AM
2000jdmciv
Sep 24, 2007 02:15 PM
johnjohn312
Jun 29, 2006 06:24 AM
