PRO's and CONS
Old Jul 5, 2007 | 07:52 AM
WattsUp's Avatar
Default PRO's and CONS
Okay i have a question...I tried searching but i did not find anything that would help out on this question...
What are the pro's and cons of using a GSR head with a type r bottom end....??
will this be like a b20vtec or lsvtec setup...or a type r setup..??
I know theres peopel that have tried this so let me know your expericence and how much hp and tq did you push out of this setup....
Old Jul 5, 2007 | 11:41 AM
Lord Helmet's Avatar
Default Re: PRO's and CONS (WattsUp$)
well the bore and stroke is the same. the type r head is the main difference. the itr pistons skirts are coated from the factory. that setup (GSR head and ITR bottom) if you retain the itr pistons, will give you a 11.1: 1 compression. It will be like a poor man type r except you don't have the b16 head or itr head to go with it. With the b16/itr head compression will be lower a little bit to 10.8: 1
Aim-MDMA
Sep 24, 2010 12:49 PM
ef8-dc2619
Feb 26, 2007 08:44 AM
digital sol
Jan 5, 2006 05:42 PM
-KangaRod-
25
Oct 11, 2003 07:41 AM
sshaikh01
Feb 10, 2003 08:06 AM
