Project Log of 90 CRX HF with a JDM h22a swap!!! 10 lbs of shit into a 5 lb bag!!!
Old May 30, 2005 | 06:26 PM
  #51
hondapride59's Avatar
Default Re: (canis)
if he has trouble with it hitting the hood, he could just get the sir hood cuz it would give him more clearance
it does look to be tighter in the front but the radiator might not be a problem but he is also doign it all custom and i salute him, i will be one to wait fo rthe hasport kit, too much custom for me to do it without it
Old May 31, 2005 | 05:46 AM
  #52
ExplicitSpeed360's Avatar
Banned.
Default Re: (hondapride59)
The motor isnt going to move that much or I should say as much as you may think. In every location that may be tight there is atleast 1/2" gap. The motor mounts are turning out really good I will have pix of the finished product tonight for the driver side and passenger side. I think its pretty much what hasport did on the passenger side. Couldn't tell from the picture. I made a whole steel unit with ears that will be welded into the car on the passenger side. On the rear crossmember near the passenger side bottom control arm bracket ( i think it is) you will need to hit it in to make clearance for the back of the tranny and also the trans drain plug. Like "2point2" but i think he may of relocated the plug? or used a allen fitting? But it gave us a little bit of a fit. Bad place for a drain plug
I called a local shop that specializes in axles. There is about an 1" we can play with on both sides to make a hybrid axle work. and for $115 a piece, I was happy to say the least.
Hasport watch out!!! lol jk!!! I was very happy how the welds turn out! You can see where the old ears were...
I used a bar to strengthen the plate
Modified by ExplicitSpeed360 at 6:45 AM 6/1/2005
Modified by ExplicitSpeed360 at 6:47 AM 6/1/2005
Modified by ExplicitSpeed360 at 6:48 AM 6/1/2005
Old Jun 1, 2005 | 10:56 AM
  #53
digitalRSX's Avatar
Nice swap!! One question though, what made you decide to go with the H series over the K series?
Old Jun 1, 2005 | 04:40 PM
  #54
Banned.
Default Re: (digitalRSX)
H series in my eyes is a better designed engine more so then the K series. More power capabilities. More power out of the box. More parts. Better in just about every way. Not to mention half the price of a K series. So to me it was a no brainer. The K series to me at this point seems kinda all hype.
Old Jun 1, 2005 | 06:30 PM
  #55
digitalRSX's Avatar
Default Re: (ExplicitSpeed360)
I want to put a K24A2 in my CRX but I don't know what kind of issues I will run into as far as fitting it under the hood. I know it will be too tall first of all. I don't know how wide it will be. I also don't know if I can use the A/C. I will have to do the OBD II conversion. There is a lot of work involved but I think that the K24A2 (TSX engine) will be well worth it.
Old Jun 1, 2005 | 08:59 PM
  #56
DohcVtecCrx's Avatar
subscribe.....wanna make an extra set of those mounts???
nice going dude subscribing to this madness!!!!!!!!!!!!
Old Jun 2, 2005 | 08:18 PM
  #57
brian g's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">H series in my eyes is a better designed engine more so then the K series. More power capabilities. More power out of the box. More parts. Better in just about every way. Not to mention half the price of a K series. So to me it was a no brainer. The K series to me at this point seems kinda all hype.</TD></TR></TABLE>
I think it's a tough sell trying to convince people that Honda took a step backward with the K-series engine.
brian g
Old Jun 2, 2005 | 08:33 PM
  #58
Banned.
Default Re: (brian g)
June 2- Well it appears all the hard work is done. All 3 motor mounts in and sittin on there on weight. I am very happy with the end result. Now its down hill, the accord shifter assembly and bracket for the altenator and clutch cable and then wirring and it should be done. Next weekend all the mods should be done. Axles will take a day to get and wirring a few days. I will keep postin up pix.
There is actually alot of room in the front!
Here is a new pic of the custom rear mount...
Old Jun 3, 2005 | 12:32 AM
  #59
BlueIntegraBoy's Avatar
Wow, I always love these threads about car buildups. Great work.
Old Jun 3, 2005 | 05:51 AM
  #60
Banned.
Default Re: (BlueIntegraBoy)
Thanks! It is a lot of work no joke but the pay off should be worth it!!!
Old Jun 3, 2005 | 06:42 AM
  #61
AudioFuct's Avatar
Looks like a great project. The only thing that really caught my eye and kind of raised a red flag, is the rear tranny mount. That bar doesnt look very sturdy and I can almost see bad things happening to those welds. Something like that, imho, should be one solid peice and not 2 pieces welded together. Or maybe, at the very least, the metal should be 2 to 3 times thicker then what you have depicted. Hopefully it works out for you and im completely wrong, though.
Old Jun 4, 2005 | 10:06 AM
  #62
Banned.
Default Re: (AudioFuct)
Thanks for the concern. The rear tranny mount is basically to balance the motor and under hard acceleration. I used thicker stuff on the rear mount too 1/4" because the design I choose. The welds to me seem unbreakable. But we will find out. The two side mounts take up all the load. So for the moment I feel very confident.
Old Jun 7, 2005 | 02:23 PM
  #63
Banned.
June 7- I finished the custom altenator bracket and tensioner a few days ago. I installed the shifter assembly out of an 90-93 accord it is a little bit smaller and not as bulky as the prelude. Plus the cables are exactly the right length. Looks like the last thing to make will be the clutch cable bracket and ill be done minus little details. I will keep ya guys posted.
Little details:
make civic radiator fit install slim fan, wirring, axles, modify obx header,
intstall teg discs all around, brake booster, master cylinder, perportioning valve
make custom e brake cables, powder coat everything, paint engine bay, install skunk2 coilovers and my agx shocks, brembo slotted rotors all around, possibly make a custom strut bar if I have the time, etc. etc. etc. so about 2-3 weeks it should be on the road...
There is about 1/2" of room between altenator and wheel well, which is plenty
90-93 accord shifter assembly installed
Modified by ExplicitSpeed360 at 3:33 PM 6/7/2005
Modified by ExplicitSpeed360 at 3:34 PM 6/7/2005
Old Jun 7, 2005 | 05:59 PM
  #64
90h22acrx's Avatar
wow nice project man. i no what your going through i have done a 2 gen crx and hatch. heres the pics. my crx https://honda-tech.com/zerothread?id=1216442 the hatch <A HREF="https://honda-tech.com/zerothread?id=1202932
" TARGET="_blank">https://honda-tech.com/zerothread?id=1202932
</A> if you need any help just ask. id like to see you cable to hydro conversion.
Old Jun 8, 2005 | 06:23 PM
  #65
DirectPortEF's Avatar
Default Re: Project Log of 90 CRX HF with a JDM h22a swap!!! 10 lbs of **** into a 5 lb bag!!! (ExplicitSpee
I'm doing same motor in ef hatch! Can you tell me what I can do for Cable to Hydraulic conversion?
Old Jun 8, 2005 | 06:27 PM
  #66
What did you do for Cable to Hydraulic conversion? I'm doing the same motor in an ef hatch, and not sure what to do!
Old Jun 8, 2005 | 06:38 PM
  #67
88ED8's Avatar
More pictures!!!!!!!!!
Old Jun 8, 2005 | 08:17 PM
  #68
Banned.
its a bracket that holds the stock clutch cable and you make ears for the hydro fork to have the cable unit slide in it. I havent made it because its too simple and its something I will do when I get the engine in for the final time after painting the bay. Tom. just gotta make my custom mounts for the civic radiator and get the gangsta lean on it . Make new mounts for the radius rods and I am pretty much done with the hard slightly hard stuff. I sat the car on the ground for the first time oil pan is a lil over 5" from the ground on stock height so i got atleast lower it 2" I wasnt too happy with that, just gotta watch over the bumps, There is about 3/4" of clearance on the hood so I was happy with that
Old Jun 8, 2005 | 08:19 PM
  #69
hondaZvic's Avatar
good job on that alt bracket can u get some pix of the tensioner u made for it?
i had made myself a custom alt bracket before, and mounted up where the PS pump went, but then my tensioner stripped and i had to go back to stock... totally sucked.
Old Jun 8, 2005 | 08:34 PM
  #70
90h22acrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ExplicitSpeed360 &raquo;</TD></TR><TR><TD CLASS="quote">its a bracket that holds the stock clutch cable and you make ears for the hydro fork to have the cable unit slide in it. I havent made it because its too simple and its something I will do when I get the engine in for the final time after painting the bay. Tom. just gotta make my custom mounts for the civic radiator and get the gangsta lean on it . Make new mounts for the radius rods and I am pretty much done with the hard slightly hard stuff. I sat the car on the ground for the first time oil pan is a lil over 5" from the ground on stock height so i got atleast lower it 2" I wasnt too happy with that, just gotta watch over the bumps, There is about 3/4" of clearance on the hood so I was happy with that </TD></TR></TABLE>
werd. place racing use to sell it before they went out of buissness.
Old Jun 10, 2005 | 01:04 AM
  #71
bokals's Avatar
nice project i love it *bookmarked*
Old Jun 14, 2005 | 06:24 AM
  #72
Banned.
Just an update, I got all of my suspension and brakes done, Teg brakes all around, brembo slotted rotors, kyb agx shocks, skunk2 teg coilovers. I also mounted my radiator with the lean. Just gotta do the new radius rod ears and a clutch cable bracket, then wirring and should be done pretty soon.
Old Jun 14, 2005 | 09:08 AM
  #73
SL0WEGG's Avatar
everything looks great so far
Old Jun 17, 2005 | 12:47 PM
  #74
notmightydx's Avatar
looks friggin sweet man! MAD props. my boy wanted this swap but opted to pick up fully built sleeved LS/VTEC swap for 7300. i told him he was stupid and should have did the Hdoubledizzle. he will be disapointed when i show him this....
subscribed
Old Jun 20, 2005 | 08:39 AM
  #75
Hotori Hanso's Avatar
Default Re: (notmightydx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notmightydx &raquo;</TD></TR><TR><TD CLASS="quote">looks friggin sweet man! MAD props. my boy wanted this swap but opted to pick up fully built sleeved LS/VTEC swap for 7300. i told him he was stupid and should have did the Hdoubledizzle. he will be disapointed when i show him this....
subscribed</TD></TR></TABLE>
tight
