Problems using FPR from d16 on a B16?
Anyone here currently using a FPR from their D16 on their B16?
I had one on my D16 and I just did a swap. Will this work? What problems will I run into by doing this? This is the one where you have to cut the OEM one in half to install.
Thanks
Thanks
if your cutting it in half to do a b&m on it, b/d/h will work with each other.
i'm running a H series on my b series, the return hose was hard to get on due to reg. having bigger outlet
you;ll need a pressure guage (buy with the b&M)
to set yout pressure correctly
Modified by darrinbrewer at 11:22 PM 8/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_PissingDog_Crx »</TD></TR><TR><TD CLASS="quote">Anyone here currently using a FPR from their D16 on their B16?
Thanks
You would need to stick it on the car and check the rail pressure to make sure its within spec. If it is, good. I honestly don't know if it will be in the correct range or not.
Thanks
</TD></TR></TABLE>You would need to stick it on the car and check the rail pressure to make sure its within spec. If it is, good. I honestly don't know if it will be in the correct range or not.
solk1dd
May 4, 2010 05:11 PM
