Is It Possible To Have More Than One Map Sensor
Old Mar 2, 2004 | 09:20 AM
.Hookedonhatch.'s Avatar
Default Is It Possible To Have More Than One Map Sensor
I have a jdm b18c (gsr) and i plugged my vx engine harness in. I plugged a three wire plug into the throttle body sensor that says [sensor assy. map] but i also have a bracket that has a sensor on it with a small vaccuum line going to the intake manifold it also says [sensor assy. map]. I dont have any other three wire plugs left. SO WHAT SHOULD I DO with it?. Just mount it and dont plug anything into it. I dont want my ecu to go into limp mode any ideas
Old Mar 2, 2004 | 11:45 AM
Default Re: Is It Possible To Have More Than One Map Sensor (Hookedonhatch)
bump - i have searched since 12:00pm and still cant find ****
Old Mar 2, 2004 | 12:04 PM
Turbogixxer's Avatar
Pic of the sensor? A lot of the sensor say that.
Old Mar 2, 2004 | 01:09 PM
Default Re: Is It Possible To Have More Than One Map Sensor (turbogixxer)
https://honda-tech.com/zerothread?id=785254
Old Mar 3, 2004 | 05:46 AM
EE_Chris's Avatar
There is only 1 MAP sensor needed for proper management of the engine. If there is a MAP sensor located on your B18C throttle body, use it.
Perhaps what is confusing you is that your original car might have had an externally mounted MAP sensor (on the firewall). I'm really not familiar with 5th gens though, just taking a stab.
What color wires does the 3-pin connector use?
attica
12
Aug 20, 2009 08:43 AM
WalkerGSR1
Oct 27, 2006 02:01 AM
'90crxSI
May 23, 2006 06:53 AM
Shiftpointshaun
Apr 2, 2004 07:58 PM
.Hookedonhatch.
Mar 2, 2004 09:34 PM
