poor mans type r
Old May 14, 2003 | 02:50 PM
Hate's Avatar
Default poor mans type r
ive been hearing that if you get a b18c1 block, have it bored to 84mm and get itr internals, use a ported b16 head that it is basically an itr engine. tru? if so, what else is needed to be done? crank, cams ect
Old May 14, 2003 | 02:51 PM
Kamin's Avatar
Default Re: poor mans type r (Hate)
you dont have to bore it go get a poor mans R
hence POOR mans.
b18c block b16 head
Old May 14, 2003 | 02:58 PM
bigblockEG's Avatar
While you are at it, throw a Civic Type R intake cam in there, with an ITR exhaust cam with some double springs... That would help as well. When you start to modify air flow it is a good idea to get the ecu chipped use some sort of engine management to "tune" the set up as well. A V-AFC will do the job for mild engine set-ups. So often is engine management overlooked..
Old May 14, 2003 | 04:01 PM
AMG's Avatar
AMG
Default Re: (bigblockEG)
Correct me if i am wrong, but i dont think you need to change the head, doesnt the gsr head have just as good of flow as the b16 or is that the type r?
Old May 14, 2003 | 05:15 PM
khang77642's Avatar
Default Re: (Si-G93)
Actually, the b16 head flows better than the GSR. There is an POST about this not too long ago. Search in the FI section.
Old May 14, 2003 | 06:21 PM
yaya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">ive been hearing that if you get a b18c1 block, have it bored to 84mm and get itr internals, use a ported b16 head that it is basically an itr engine. tru? if so, what else is needed to be done? crank, cams ect</TD></TR></TABLE>
that would be called the "rich idiot's type r"
Old May 14, 2003 | 06:56 PM
Newman's Avatar
New User
Default Re: poor mans type r (Kamin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hate &raquo;</TD></TR><TR><TD CLASS="quote">have it bored to 84mm and get itr internals</TD></TR></TABLE>
Heh... if you use ITR pistons, you'll have "zero" compression and lots of "rod knock"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">
hence POOR mans.
b18c block b16 head</TD></TR></TABLE>
Pretty much, but if you just slap a B16 head to a stock GSR block, you're compression is going to drop to around 9.8:1 so unless you add some higher compression pistons (ITR, SiR, or even PCT/CTR), then it's not really worth doing a poorman's ITR in my opinion.
Old May 14, 2003 | 09:38 PM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kamin &raquo;</TD></TR><TR><TD CLASS="quote">you dont have to bore it go get a poor mans R
hence POOR mans.
Exactly
Old May 15, 2003 | 12:00 AM
Kamin's Avatar
Default Re: poor mans type r (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">
c-speed says 10:1 with USDM pistons and 10.6:1 with JDM pistons (both GSR pistons)
http://www.c-speedracing.com/h...c.php
Old May 15, 2003 | 06:31 AM
@irborne's Avatar
http://www.c-speedracing.com/h...c.php</TD></TR></TABLE>
woow....11.4 cr w/ b18c block+b16head+pr3 pistons (how accurate is this calculator anyway?)
Old May 15, 2003 | 10:11 AM
Mentat Ghola's Avatar
11.4 c/r with b16a1 pistons? IS THIS TRUE? I have my old b16 block laying around, and my b18c in my civic.
Old May 15, 2003 | 10:34 AM
Newman's Avatar
New User
C-speedracing's compression calculator is off, and has always been off. I do the calculation myself and come up with those number so I trust my numbers and forumlas rather than somebody elses. Remember, it's the internet so people can post up anything, and others may believe it, even if it's not accurate. Just a frame of reference..... a stock US GSR compression is 10.2:1 and if you slap on a B16 head to that block, you drop .2-.4 points of compression, depending on the head deck and head gasket, and also due to the larger cc on the B16 head, and if it's ported.
Old May 15, 2003 | 10:37 AM
Newman's Avatar
New User
Default Re: (The B Man)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The B Man &raquo;</TD></TR><TR><TD CLASS="quote">11.4 c/r with b16a1 pistons? IS THIS TRUE? I have my old b16 block laying around, and my b18c in my civic.</TD></TR></TABLE>
I calculate a stock B16 head, stock GSR block, no milling or decking, stock GSR rods & crank and PR3 SiR1 pistons to come out to 11.61:1 compression. If you use P30 SiR2 pistons, 11.79:1 compression. If you use JDM ITR pistons, 11.13:1 compression.
Old May 15, 2003 | 10:38 AM
WAFFLES's Avatar
C-speedracing's compression calculator is off, and has always been off. I do the calculation myself and come up with those number so I trust my numbers and forumlas rather than somebody elses. Remember, it's the internet so people can post up anything, and others may believe it, even if it's not accurate. Just a frame of reference..... a stock US GSR compression is 10.2:1 and if you slap on a B16 head to that block, you drop .2-.4 points of compression, depending on the head deck and head gasket, and also due to the larger cc on the B16 head, and if it's ported.</TD></TR></TABLE>
Correction, according to honda/acura, a stock GSR compression is 10:1, B16 is 10.2:1.
And yes he is right, C-speeds calc is off. I 99.9% of the time trust what facts Newman states, because he knows his ****.
Old May 15, 2003 | 11:35 AM
Kamin's Avatar
Default Re: (Newman)
I stand corrected
kevheslop
Sep 23, 2009 10:43 AM
civic_<3
10
Jul 19, 2009 08:25 AM
heritage36
May 31, 2009 03:57 PM
b20_driven
Oct 14, 2006 04:38 AM
TEGGRY
Dec 29, 2005 09:30 AM
