please help fast!!!!! b16 swap
Old Jul 23, 2002 | 06:01 PM
speedy-crx's Avatar
Default please help fast!!!!! b16 swap
exactly what water pump do you need for swaping b16a1---hasport says that a 94 del sol vtec will work but the one we bought wouldnt fit so did they give us the wrong one or do you need to modify it in some way...
Old Jul 23, 2002 | 06:53 PM
speedy-crx's Avatar
Default Re: please help fast!!!!! b16 swap (needahatch)
please help we have to have the car done by saterday because my prelude is goin in for its overhall and plus we need the car and my shop wont hold both
Old Jul 23, 2002 | 08:36 PM
Redline130's Avatar
The Del Sol vtec one should work. Any B-series vtec pump should bolt up. I used a Si one. Just make sure that it's for a B16, B17, or a B18C. BTW, there's no h in VTEC.
[Modified by cyber13, 9:37 PM 7/23/2002]
Old Jul 24, 2002 | 12:33 AM
4drlsvtec's Avatar
Use a b16 one or GSR there both the same part...
Don't use the B18 "LS" cause the teeth are smaller=ls timing belt
Doug, 4drlsvtec
Old Jul 24, 2002 | 09:01 AM
speedy-crx's Avatar
Thanks alot for the help guys im on my way to auto zone right now ...
Old Jul 24, 2002 | 09:02 AM
speedy-crx's Avatar
Default Re: please help fast!!!!! b16 swap (cyber13)
hey what did you put your 16 in cause I got a few more ? if it was into si crx...
Old Jul 24, 2002 | 09:23 AM
eg6ajk's Avatar
b16a any gen. will bolt up, no mods needed....most likly you go a d16z6 h20 pump
Old Jul 24, 2002 | 09:49 AM
311's Avatar
311
Default Re: please help fast!!!!! b16 swap (eg6ajk)
just count the teeth, and the size of the teeth, and compare.
90 JDM EF8
May 16, 2006 05:45 PM
drunknmonkey18
Oct 23, 2004 09:01 AM
DrRoboto
Apr 4, 2003 06:44 PM
kanzenr91si
Feb 22, 2003 09:20 PM
nsxmatt
Nov 17, 2002 04:28 AM
