P0117 ECT circuit low
Old May 29, 2015 | 03:14 PM
existanzcivicb20's Avatar
Default P0117 ECT circuit low
1997 Civic with a LS swap LS ECU and LS Harness. For some reason I'm getting this code I checked the wire that goes back to the ECU and its fine I get 5V from the ECU and I get 5V to the sensor. I checked the ground wire by putting one end of my DVOM to batter + and the other to the wire and I get good ground what am I missing? How do I know If the sensor is good?
Old May 29, 2015 | 03:18 PM
Former User's Avatar
Default Re: P0117 ECT circuit low
Ohm test the sensor and check the ground wire for an open or short.
Old May 29, 2015 | 05:42 PM
Do you know where that ground wire runs to ?
Old May 29, 2015 | 05:45 PM
ECU
Old May 30, 2015 | 05:05 AM
HondaPartsHero's Avatar
Technical Hero
Old Jun 1, 2015 | 01:55 PM
I only see pin 2 from connector D being the 5V for the ECT. Would Pin 11 and 12 be for the gound for the ECT?
Old Jun 2, 2015 | 06:51 AM
Bump
Old Jun 2, 2015 | 07:09 AM
What color was the ECT wire that you said had 5V?
Originally Posted by RonJ@HT
Ohm test the sensor...
Did you do this^?
The ECT sensor grounds at D11. Do a continuity test to verify it is connected, and also test wire for a short to ground.
Old Jun 2, 2015 | 01:19 PM
Blue and black
Old Jun 2, 2015 | 01:29 PM
Originally Posted by existanzcivicb20
Blue and black
You may be testing the wrong connector. The Civic ECT sensor connector has Red/Wht (power) and Grn/Blk (ground) wires.
Again, did you Ohm test the sensor?
Old Jun 3, 2015 | 10:28 AM
Your right the color is Red with white strip 5V
Old Jun 3, 2015 | 03:41 PM
3.0 ohm on the sensor and with a scan tool in getting a reading of 215 C on the ECT and 23on the IAT and about 1 Ohm resistance from the pig tail to the ECU for D11 (green wire)
Old Jun 4, 2015 | 12:12 PM
Any ideas?
Old Jun 6, 2015 | 07:14 AM
Bump
Old Jun 8, 2015 | 02:53 PM
Still can't figure it out
Old Jun 11, 2015 | 07:18 AM
Any ideas will help at this point
Old Jun 14, 2015 | 09:33 AM
Bump
Tman6925
Apr 9, 2009 04:31 PM
TN90accord
Aug 19, 2006 06:55 AM
DaCRXboi
Aug 20, 2005 10:40 PM
dingusjt
Nov 13, 2003 10:18 AM
