oo si tranny ??
Old Aug 23, 2003 | 06:06 PM
tonetouch20's Avatar
Default oo si tranny ??
i have a grind in 5th gear my friend has an older teggy i think its a 92 and he took his tranny out would i be able to take the synchros out of his and into mine?? and also would a 96 gsr tranny fit on his older integra?? thanks tonetouch20@yahoo.com
Old Aug 23, 2003 | 08:36 PM
VTECVillain's Avatar
Default Re: oo si tranny ?? (tonetouch20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonetouch20 &raquo;</TD></TR><TR><TD CLASS="quote">i have a grind in 5th gear my friend has an older teggy i think its a 92 and he took his tranny out would i be able to take the synchros out of his and into mine??</TD></TR></TABLE>
No the 92 B18A1 YS1 tranny synchros will not work. If it were a 92 YS1 tranny from a GSR it would because the 92-93 GSR cable tranny uses the same synchros as the 94+ hydro B series tranny's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">would a 96 gsr tranny fit on his older integra??</TD></TR></TABLE>
No because that's a hydro tranny that you would be trying to put into a cable clutch setup car.
Old Aug 23, 2003 | 08:44 PM
Default Re: oo si tranny ?? (VTECVillain)
what about if he did a hydro conversion to his teg.would that work??
Old Aug 23, 2003 | 08:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonetouch20 &raquo;</TD></TR><TR><TD CLASS="quote">what about if he did a hydro conversion to his teg.would that work??</TD></TR></TABLE>
Yeah but good luck with that one
Old Aug 23, 2003 | 08:51 PM
what does that mean?? hes plannin on going to a junk yard 2morrow and getting 1 out of a newer civic..would that be really hard to do
Old Aug 23, 2003 | 08:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonetouch20 &raquo;</TD></TR><TR><TD CLASS="quote">would that be really hard to do</TD></TR></TABLE>
Yes, altough it's much easier to install a cable clutch into a hydro equipped car. Basically you will need to: change the pedal board, cut a hole in the firewall to mount the clutch master cylinder, run the hard lines from there to the slave cylinder, custom fab a tranny mount or adapter, switch out the VSS, etc. It's not your typical backyard weekend project....
Old Aug 23, 2003 | 09:01 PM
how much do u think something like that would run u parts wise.
swaytec360
Mar 9, 2005 06:21 PM
SL!M
Aug 30, 2003 09:28 AM
dose
Mar 31, 2002 11:28 PM
