Oil Light Is Blinking NEED HELP!!
Old Feb 1, 2003 | 03:07 PM
Stroker
Guest
Posts: n/a
Default Oil Light Is Blinking NEED HELP!!
OK, ive got a b16a3 in a 98 EK. Everything was going fine, until three weeks ago. I was driving through some high speed turns in the mountains, and my oil light came on. I stopped the car imediatly, checked the oil, it was about a third of a quart low, so i topped it off and drove home with no problems. My car sat for about three weeks while i was doing some suspension work. Today i went to get a final alignment, and the oil light started blinking. I looked on the garge floor, there was no oil on it. I checked the oil level, it was fine. The light goes out if i bring the RPM's above idle. So what gives??? Info would be great.
Old Feb 1, 2003 | 03:30 PM
tnbigdawg's Avatar
Default Re: Oil Light Is Blinking NEED HELP!! (stroker)
it seems like your oil pump is going bad.
also check to see if you crushed your oil pan, you might have a clogged oil pick up.
Old Feb 1, 2003 | 03:59 PM
Kamin's Avatar
Default Re: Oil Light Is Blinking NEED HELP!! (tnbigdawg)
sounds like a clogged pickup screen.
Old Feb 1, 2003 | 06:38 PM
Stroker
Guest
Posts: n/a
Default Re: Oil Light Is Blinking NEED HELP!! (Kamin)
Do i just pull the pan to do that??
Old Feb 1, 2003 | 07:53 PM
Ekasey's Avatar
yeah you can pull the pan to check it but pretty sure it's an oil pump, and thats not an oil light thats an idiot light (means way low low oil) have a nice day
Old Feb 2, 2003 | 09:47 AM
irev210's Avatar
Default Re: Oil Light Is Blinking NEED HELP!! (eLusive ek4)
dont drive around, u are probably murdering your bearings
Old Feb 2, 2003 | 01:05 PM
Stroker
Guest
Posts: n/a
The car hasnt moved, i got a new oil pump and guess what???
The light went off. LOL thanks guys
Greg50Lt
Honda Civic (2006 - 2015)
Nov 7, 2009 03:08 AM
acuraman08
Apr 3, 2008 07:04 PM
FmXRider991
Apr 11, 2005 02:34 PM
Mr. Samurai
10
Feb 28, 2005 05:59 PM
1hotintegra
Dec 15, 2002 08:00 PM
