Oil Leak ?
I have a 95 B18B in my 93 Honda del Sol. I have had problems with oil leaking in to the spark plug cylinders ever since the swap. I have replaced the valve cover gasket and o-rings twice with no change. Also re-torqued the valve cover and replaced the cap nut washers. Warped valve cover? Any other ideas? I can't "read" my plugs because they are soaked in oil from above every time I pull them.
is there oil only on the top of the plugs, or on the electrodes as well. if the latter, you might want to do a compression/leakdown test to rule out some bad rings.
CRXREFIC
Dec 17, 2010 01:45 AM
