Oil catch can setup b20vtec
Old Apr 29, 2013 | 09:32 AM
joiv21's Avatar
Default Oil catch can setup b20vtec
I have a oil catch can with a filter on top two connecting ports and a screw on the bottom for drain. One of the ports connects to the Pcv and the other will t-tap to both ports on the back of b20, then mount the catch can high. Does this sound correct?
Old Apr 29, 2013 | 02:04 PM
joiv21's Avatar
Default Re: Oil catch can setup b20vtec
Bump, before I build up to much crankcase pressure lol
Old Apr 29, 2013 | 03:28 PM
joiv21's Avatar
Come on someone knows
Old May 2, 2013 | 05:27 PM
joiv21's Avatar
bump
Old May 2, 2013 | 05:30 PM
mechanix619's Avatar
Put the catch can between the valve cover nipple and PCV. You don't need to use the back of the block ports.
Old May 3, 2013 | 04:50 AM
nealnanoHX's Avatar
B20 Vtec will have no PCV valve. Yes use the nipple on the valve cover and 1-2 nipples on the back of the block.
Old May 3, 2013 | 07:18 AM
I forgot, the B20 will have a PCV on the valve cover that goes to the intake manifold.
Old May 3, 2013 | 09:53 AM
joiv21's Avatar
So connect one of the hoses to my Pcv and connect two more hoses to the ports on the back?
Old May 3, 2013 | 11:43 AM
nealnanoHX's Avatar
No 1 or more to the back of the block. You will need H22 oil cooler line fittings for this. I have 1 off the back of the block and 1 from my valve cover going to my vent can.
Old May 4, 2013 | 08:34 AM
joiv21's Avatar
cool thanks for the knowledge
insidiouseg-6
Aug 6, 2008 07:54 PM
be18see1
Jul 17, 2008 12:53 AM
showtymers619
May 1, 2004 09:21 PM
my_slow_civic
Nov 18, 2003 11:52 AM
