obd2b questions
Old Oct 21, 2012 | 02:40 PM
Hatchback_Pat's Avatar
Default obd2b questions
So heres a little info. I have a 2000 integra ls that im pulling the motor out of and putting into my 95 civic hatch. By some research i was doing i believe this motor is obd2b. I got a 2000-2001 integra ecu off ebay. And when i was looking for a obd1-obd2 jumper harness i read something on rywire that if im using a usdm ecu im going to have problems because of the ingnition transponder wont match up and wont start. And they say to use a differant ecu. My questions are can i bypass this any way and or what differant ecus can i use if i run into this problem?
Old Oct 21, 2012 | 08:22 PM
Default Re: obd2b questions
Anybody? Ive been reading i was wondering can i jist bist of the imobolizer chip off or can i just use a obd1 ecu?
Old Oct 21, 2012 | 09:02 PM
EFinAwesome's Avatar
Use your obd2 harness plug it into the towers and use a obd1 p75 and your done.
Old Oct 22, 2012 | 07:57 AM
Thanks for clearing that up for me much appreciated. If i do this i wont need a jumper harness and i can just plug the ecu into my civic
Old Oct 22, 2012 | 04:10 PM
Yes sir. Only need a jumper harness if you want to run a obd2 ecu
VTed
Engine Management and Tuning
Mar 9, 2012 03:44 AM
jdmchickx
10
Oct 26, 2011 06:03 PM
ek coupe
Feb 19, 2009 09:05 AM
sshaikh01
Mar 22, 2003 07:10 AM
4drb18ek
Mar 1, 2003 07:42 AM
