OBD2 to OBD1 distributor
Old Jul 19, 2004 | 11:21 AM
Turboteggy's Avatar
Default OBD2 to OBD1 distributor
My 94 Integra RS distributor it toast. I can get a OBD2, 2000 B20Z distributor for next to nothing.
Can I cut the clips and solder the wires back together, (so the OBD2 distributor has an OBD1 clip) or are there more/less wires that would make this impossible?
Thanks in advance guys.
Old Jul 19, 2004 | 11:49 AM
boomslang's Avatar
Default Re: OBD2 to OBD1 distributor (Turboteggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turboteggy &raquo;</TD></TR><TR><TD CLASS="quote">My 94 Integra RS distributor it toast. I can get a OBD2, 2000 B20Z distributor for next to nothing.
Thanks in advance guys. </TD></TR></TABLE>
You can use the OBD2 distributor just fine. You can cut/splice the wires or remove the pins from the OBD2 connector and put them in an OBD1 connnector.
The 2 OBD2 IGN wires on that go to the 2-pin OBD1 connector have different size pins. They are the solid blue and black/yellow wires.
Old Jul 20, 2004 | 02:04 PM
Turboteggy's Avatar
Default Re: OBD2 to OBD1 distributor (boomslang)
OK cool.
What about the crank sensor? I've heard mine has it in the distributor, but it's not in the OBD2 distributors.
True?
Old Jul 20, 2004 | 03:50 PM
hondaZvic's Avatar
true, obd1 dizzys have everthing inside them. obd2 does not.
Old Jul 20, 2004 | 04:15 PM
boomslang's Avatar
Default Re: OBD2 to OBD1 distributor (hondaZvic)
The crankshaft fluctuation sensor (CKF) is mounted near the crankshaft. Not in the distributor.
OBD1 cars don't have a CKF. OBD2 cars do.
Old Jul 20, 2004 | 05:49 PM
hondaZvic's Avatar
well then, ckp/tdc & cyp.
Old Jul 21, 2004 | 08:40 AM
owen_the_soyboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomslang &raquo;</TD></TR><TR><TD CLASS="quote">
You can use the OBD2 distributor just fine. You can remove the pins from the OBD2 connector and put them in an OBD1 connnector.
</TD></TR></TABLE> but hey, DONT cut them!
just remove the pins from the obd2 connector and stick them into the obd1 connector!
ej8_fredi
Mar 28, 2009 11:10 PM
nikkarocky
Texas -OK -LA (Sales)
12
May 3, 2007 10:11 PM
92EG8
Dec 3, 2006 06:41 PM
specie
Jun 14, 2004 06:32 PM
