obd2 b18c1 knock sensor location?
Old Sep 27, 2007 | 11:31 AM
be18see1's Avatar
Default obd2 b18c1 knock sensor location?
where is the knock sensor on a obd2 b18c1? i swapped my obd2 b18c1 into my 1993 DA. is the crank position sensor the same as the knock sensor? theres a sensor down by the crank pulley, but theres not sensor on the back on the block like my friends' b16s. note-i swapped my obd1 dizzy internals into the obd2 case.
edit-the car runs, but im pretty sure vtec doesnt engage, and when it revs it drops below 550 rpms and back up to 750.
Old Sep 27, 2007 | 11:51 AM
pgpbubble's Avatar
Default Re: obd2 b18c1 knock sensor location? (be18see1)
Old Sep 28, 2007 | 10:19 AM
be18see1's Avatar
its not there.
Old Sep 29, 2007 | 05:32 PM
Honda Sport's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">its not there.</TD></TR></TABLE>
then put one there and wire it up. lol
Old Sep 29, 2007 | 09:53 PM
dude_123's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by be18see1 &raquo;</TD></TR><TR><TD CLASS="quote">where is the knock sensor on a obd2 b18c1? i swapped my obd2 b18c1 into my 1993 DA. is the crank position sensor the same as the knock sensor? theres a sensor down by the crank pulley, but theres not sensor on the back on the block like my friends' b16s. note-i swapped my obd1 dizzy internals into the obd2 case.
edit-the car runs, but im pretty sure vtec doesnt engage, and when it revs it drops below 550 rpms and back up to 750.</TD></TR></TABLE>
Is there a hole where the ks supposed to be since the blocks that don't have ks doesn't even have the webbing to put the ks on.
The sensor by the crank pulley is the Crankshaft Speed Fluctuation (CKF) sensor. Crank position sensor is located in the dizzy.
Old Sep 30, 2007 | 06:17 AM
be18see1's Avatar
Default Re: obd2 b18c1 knock sensor location? (dude_123)
im going to sound like a complete moron. i found a green plug back there, but its already plugged into somthing. is this plug the sensor i want? and what could possibly be plugged into it? i assumed it was like an oil pressure sensor or something... god i sound stupid.
Old Feb 16, 2010 | 10:20 PM
fenix4o9's Avatar
http://rywire.com/store/faqdesk_info...6e410182f6c602
Old Feb 21, 2010 | 03:17 PM
SpoonCivicSir20's Avatar
No Sales Forums
are you sure its a b18c and not a b18b?
Old Feb 21, 2010 | 05:58 PM
HondaPartsHero's Avatar
Technical Hero
Old Oct 9, 2010 | 01:44 PM
the1337aaron's Avatar
Is knock sensor 1 wire or 2 plug
Superfriend
Northeast (Sales)
Jul 21, 2009 05:48 PM
jr000
Sep 9, 2007 05:52 PM
chu77
Jul 16, 2006 03:39 PM
ComputerJLT
Feb 13, 2005 01:15 PM
