OBD1 to OBD2 for BAR
Old Mar 18, 2005 | 12:12 AM
hazard_one's Avatar
Default OBD1 to OBD2 for BAR
im swapping in a 00 ls motor but i have a 95 civic. i want to just run a ODB1 ecu using a obd2 to obd1 jumper but i would need to run the ODB2 ecu to pass the bar. is there anyway to temporarily wire up the odb2 ecu just for the bar and switch it back to the obd1 ecu?
Old Mar 18, 2005 | 12:13 AM
hazard_one's Avatar
Default Re: OBD1 to OBD2 for BAR (hazard_one)
or would running the 95 obd1 ecu be ok? in other words does the ecu have to be the same year as the motor?
Old Mar 18, 2005 | 12:16 AM
hazard_one's Avatar
oh schit i just found a jumper for obd1 to obd2 from one of the sponsors. lol. anybody know if this will work?
Old Mar 18, 2005 | 10:28 AM
hazard_one's Avatar
nobody huh
Old Mar 18, 2005 | 12:31 PM
hazard_one's Avatar
somebody help me out here... i just found an obd1-obd2 harness cheap
Old Mar 19, 2005 | 03:15 AM
hazard_one's Avatar
Old Mar 23, 2005 | 12:01 PM
castlenutz's Avatar
idk if its the same but i just put a b18c5 in my 93 civic, and im running the stock p28 ecu i just had to get it re-programed by skunk2 for DOHC ect...
Old Mar 23, 2005 | 12:28 PM
Blown90hatcH's Avatar
That OBD2b integra ecu has an immobilizer in it that will not work.
Old Mar 23, 2005 | 02:15 PM
hazard_one's Avatar
Default Re: OBD1 to OBD2 for BAR (Blown90hatcH)
****. so is there any way i can pass the bar with a 2000 b18b1?
Old Mar 23, 2005 | 06:37 PM
dustin's Avatar
Tell them it is a 95 motor, and hook everything up obd1 style.
Old Mar 24, 2005 | 11:22 AM
neeks's Avatar
Default Re: OBD1 to OBD2 for BAR (dustin)
if you run the obd1 to obd2 wiring harness you cant pass the bar
they check what codes youre running and that jumper will bypass your o2 and knock sensors
you have to convert your whole car to obd2
thats what i had to do..new oil pump, alternator, injectors, wiring harness, ecu etc etc..
just dont get pulled over =x
Old Jul 16, 2005 | 11:39 AM
go2sleep's Avatar
Default Re: OBD1 to OBD2 for BAR (neeks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neeks &raquo;</TD></TR><TR><TD CLASS="quote">
thats what i had to do..new oil pump, alternator, injectors, wiring harness, </TD></TR></TABLE>
the wiring harness as in the one in car and engine bay?
Old Jul 16, 2005 | 06:10 PM
slomofo's Avatar
GDD Member
Why don't you just run an OBDI intake manifold/injectors/valve cover, cut the Crank sensor wire off so nobody can see it, then run an OBDI P75 and tell them that you blew the head gasket and got a replacement head from an 00. They will see an OBDI set up, but the stamp on the head will indicate OBDII, so just lie to explain the OBDII head.
Old Jul 18, 2005 | 05:41 AM
iakona's Avatar
Default Re: (slomofo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Why don't you just run an OBDI intake manifold/injectors/valve cover, cut the Crank sensor wire off so nobody can see it, then run an OBDI P75 and tell them that you blew the head gasket and got a replacement head from an 00. They will see an OBDI set up, but the stamp on the head will indicate OBDII, so just lie to explain the OBDII head.</TD></TR></TABLE>
thank you. he's on the right track,
you can swap in an OBD2 motor, just get all the OBD1 peripherals and swap them onto the motor, then install. you will still be OBD1, just OBD2 short block. you will have less wiring issues and it will pass visual.
yes, it is kind of expensive, but if you want it done legal and correct, that is the way to go. good luck
Old Jul 19, 2005 | 12:31 PM
klungemonger's Avatar
that's right, you don't have to pass OBD2 level inspection just becuase you have an OBD2 compatible motor. You can always put newer engines in older cars, but not the other way around. If you go OBD2 you'll have to hook up a secondary O2 sensor after the cat as well as the crank sensor. Blah!!! Don't do that.
brendan427
Oct 16, 2012 10:30 PM
thanh4o8
May 16, 2008 11:10 AM
43MA
Oct 30, 2002 04:58 AM
