OBD1 Distributor Wiring For OBD0 Conversion TO OBD1?
Old Oct 18, 2003 | 07:52 AM
Ruby Civic's Avatar
Default OBD1 Distributor Wiring For OBD0 Conversion TO OBD1?
OK, what to do with wiring in order to plug the obd1 distributor into the basically obd0 harness when doing obd0 TO obd1 conversion?
Did search and answer not clear on this, thanks all...
Old Oct 18, 2003 | 06:48 PM
Chiclets's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (Ruby Civic)
bump
i need this info too
Old Oct 18, 2003 | 07:13 PM
chrisCNL's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (bluedemon)
if you are still using a OBD0 ecu you cannot use a OBD1 distrubutor on the vehicle. it wont run right unless you change the ECU over to a obd1 ecu.
Old Oct 19, 2003 | 07:55 AM
Ruby Civic's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (chrisCNL)
understood, but am running an obd1 p28 and am doing the conversion so that was why i was asking...
can anybody cut up a bad obd1 vtec distributor and give up the plug and wiring?
need one if so
Old Oct 19, 2003 | 10:42 AM
SiR831's Avatar
I used the OBD1 distributor connector (body side) and repinned all the OBD0 wires into the OBD1 connector. Worked fine!
Old Oct 19, 2003 | 05:15 PM
mr. wu's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (SiR831)
what you need to do is get a plug that will match the one on your distributor, then pull the pins out of you obd0 engine harness and plug them into the obd1 engine harness plug. just put the pins in so they matched in color on both sides. there are two white wires on the obd0 harness, you take the bigger of the two white wires and that one matches to the green and yellow wire on the obd1 distributor, and those should be the only wires that don't match by color. i hope that helps.
Old Oct 27, 2003 | 11:59 AM
Renegade's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (mr. wu)
Good timing for the post, I am doing this today.
Old Oct 27, 2003 | 05:00 PM
Ruby Civic's Avatar
Default Re: OBD1 Distributor Wiring For OBD0 Conversion TO OBD1? (Renegade)
hey let us know how that goes..........
Old Dec 10, 2003 | 06:30 PM
gomer124's Avatar
somebody get poison to make a diagram on this
Old Dec 10, 2003 | 08:13 PM
RuthlessEF-9's Avatar
but what if your doing a dx-si swap then an obd 0 to obd 1
im stuck here i need help
bump
Old Dec 11, 2003 | 04:07 AM
Ruby Civic's Avatar
Default Re: (D16z6turbs)
what stage are you at - have you switched to si specs yet??
KevinEF7
Oct 29, 2012 01:15 PM
949
Jul 4, 2009 09:18 PM
Norcalstoppy
Oct 15, 2002 01:29 PM
Norcalstoppy
Jul 13, 2002 08:02 AM
